It is currently Mon Jul 21, 2025 1:58 pm
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
PostPosted: Tue Jun 17, 2008 1:12 pm
My 1330cc S/C Mini runs around 9.0:1 compression. And maxes at around 7psi (although usually doesn't see that, usually around 5psi on hard take offs. So much torque theres no need to ring it out beyond 6000 rpm)
I use an SC12 'charger from a Corolla. It runs around 1200ccs per revolution as oppoised to a tiny 300 or 500.
It's fun to drive, very grunty, great up and around hills (I live in a hilly area) with all that bottom end power. But can be a bit unreliable. I've broken an idler gear, and taken a lot of my gearbox with it. The car can easily overheat if the cooling system is not 100%. Burns a fair bit of oil these days, only done about 12,000kms supercharged. Also crankcase breatheing is a big issue, the motor just cant seem to get enough breathing.
And I think I'll need to move to better valves and valve guides sooner or later.
But that's no big deal, I've got a more powerful and much smoother Mini on the build.
PostPosted: Tue Jun 17, 2008 2:38 pm
my 1360cc s/c Mini runs around 8.0:1 compression, it spikes to about 6psi currently.
like slinkey i am using an SC-12 from a toyota MR2, a bloke in SA makes kits to fit them to minis, "92" on here.
there are many threads about this kit on ausmini if you do a little digging.
you should ask ben "92" about it, otherwise LINK in victoria also sell a supercharger kit.
PostPosted: Tue Jun 17, 2008 10:20 pm
ausmini mod
ausmini mod
I think you will find a huffer gives boost well before a turbo does, so more likely to give detonation or pinging, the air is hotter too (with no intercooling).
I'd be aiming for not more than 8.5:1 with a supercharger. :wink:
Having said all of that... I guess there lies the answer! Fit an intercooled turbo setup instead :)
Pete.
PostPosted: Wed Jun 18, 2008 12:20 pm
There's always water/methanol injection etc.
But if it's pinging and detonating on 98 octane fuel, try adjusting your ignition timing, reduce the advance a bit. Ok you'll probably lose some power, but the boost will more than make up for it. And the bottom end torque, due to the instant boost from the supercharger will make it a lot of fun to drive anyways, shouldn't ping or detonated under low boost anyways.
PostPosted: Wed Jun 18, 2008 3:36 pm
9.5:1 might not be too high a comp. ratio due to the higher octane rating of the LPG.
Cam would be the thing I would worry about more, as mentioned previously.
I say give it a go. get a SC12 and a kit from 92 and have a play with it. If it doesn't run well take it off and sell it. you will be no worse off than you are now. :wink:
-James.
Toyota 4EFTE Powered Minivan.
