It is currently Mon Jul 21, 2025 2:04 pm
PostPosted: Mon Jun 30, 2008 7:21 pm
I have a Lucas electronic dizzy on my metro 1300, it has a 3 pin socket on the ignition module.
like this:
Does anyone know what each pin is so I don't fry the module?
Any help would be appreciated.
Thanks,
Gig
67 Deluxe - Red and white
69 Deluxe - Sugercane Grey
PostPosted: Mon Jun 30, 2008 10:25 pm
I believe that only 2 pins are used,,, i`ve fitted quite a few of these in the past & i have the diagram here in my computer somewhere, i`ll try to find it & post it up for you
PostPosted: Mon Jun 30, 2008 10:46 pm
Yes, only 2 pins used:
Top one goes to coil +ve, bottom one to coil -ve.
If you are fitting this to an earlier car make sure that the wiring from the ignition switch to the coil +ve is direct (not via a ballast resistor or ballast wire).
PostPosted: Tue Jul 01, 2008 8:21 am
Hey thanks guys,
Jules when you say earlier car, I have a new loom for a mk1 cooper s, so do I take it there is no ballast wiring?
Gig
PostPosted: Sun Jul 06, 2008 11:55 pm
By an earlier car I really meant anything earlier than about mid 1980s when electronic ignition started to be fitted as standard!
I don't know whether the Mk1 S had a ballast resistor - but probably not. Anyone?
PostPosted: Mon Jul 07, 2008 8:25 am
BG,
Oz Minis never had ballast wiring.
If you need to run a ballasted coil (1.5 ohm) just buy a ballast resistor from Supercrap etc and wire it in series. :wink:
