It is currently Sun Jul 20, 2025 6:25 am
Post new topic Reply to topic  [ 44 posts ]  Go to page Previous  1, 2, 3
PostPosted: Sat Mar 22, 2008 4:34 pm
Kennomini wrote:
I noticed your red line is set a 7500rpm, good luck :lol:
its funny you noticed that..
I would have to be retarded if I needed a red line to tell me when my motor was going to blow up :D
Its not set really its just where it is,
It wont see much more than 4 grand in situ. Once its in the car I will flog it only sometimes. If its in pain I will back off regardless of what the tacho sez.
blokeinamoke wrote:
PostPosted: Sat Mar 22, 2008 9:44 pm
5000 pushing it for me, however mines only a standard engine. It's looking good though, keep it up 8)
PostPosted: Mon Mar 24, 2008 9:25 pm
more vids to follow
http://s92.photobucket.com/albums/l13/m ... lly338.flv
I ran it for about 20mins at 2 grand.
I am fairly confident its not going to backfire through the carby so I can put a filter on and it wont get burnt
I will do something similar tomorrow again.
I may even try and engage a gear to see if the box is ok.
blokeinamoke wrote:
PostPosted: Mon Mar 24, 2008 10:21 pm
this is a short clip of what my neighbours have to put up with.
Its loud just at idle. i should have started it sans pipe first :D
http://s92.photobucket.com/albums/l13/m ... t=idle.flv
http://s92.photobucket.com/albums/l13/m ... rrun-1.flv
I didnt let it idle for too long. I will tighten the head and redo the tappets tomorrow before I give it another squirt.
blokeinamoke wrote:
 Post subject: nice
PostPosted: Tue Mar 25, 2008 5:58 pm
good work..
i might have to give this ago :D :D :D :D :D
i like to drive on rails
PostPosted: Thu Mar 27, 2008 11:01 am
I've always been told to run in an engine under load, and at varying revs... sitting at the one rpm for a long time doesn't do it any good, and not having it under load won't let it expand the rings and the bores glaze up
or so I've been told.... :? :roll:
PostPosted: Thu Mar 27, 2008 11:46 am
Bedding in the Cam and Followers..If they are new
PostPosted: Fri Mar 28, 2008 7:19 am
Like gaf said I just did that to bed the cam in.
I only start it up now to adjust timing or to check and see if I have fixed the friggin leak in the rocker cover :evil:
blokeinamoke wrote:
PostPosted: Fri Mar 28, 2008 4:55 pm
Tip, glue the rocker cover gasket to the rocker cover with contact adhesive, then use permatex non-hardening sealant between the gasket and the head.
You can pull the rocker cover off easily to adjust the rockers and the gasket will remain undamaged and not leak.
PostPosted: Fri Mar 28, 2008 8:37 pm
Thanks Morris,
I read that tip in one of your previous threads.
I have to go buy a timing light tomorrow so I will get some stuff.
blokeinamoke wrote:
PostPosted: Fri Mar 28, 2008 8:47 pm
Thanks Morris,
That Permatex #3 sealant is no more, it is now called Loctite (brand) #3.
ps. if you fit an alloy cover, you don't need any adhesive/sealant, the heat of the head tends to stick the gasket down and the alloy cover is flat so doesn't distort it.
8)
PostPosted: Sat Mar 29, 2008 8:09 am
Thanks Morris,
8)
I have only a pressed steel rocker cover. My fist is actually really tight :D
I have another couple here so if there is no joy with the glue and such I will try a different one. The one I am using has the tabs for the gasket and the other one has not.
blokeinamoke wrote:
PostPosted: Sat Jul 19, 2008 10:57 pm
I fired her up in situ today for the first time.
I still have some wiring issues but its alive. Its just straight out the headers so its loud. The idle is set fairly low so it shakes like a drag car. Is good to have made some more progress
http://s92.photobucket.com/albums/l13/m ... engine.flv
blokeinamoke wrote:
PostPosted: Sun Jul 20, 2008 11:37 am
Milatsmadmini
love that idle.... 8) very hot! sounds great!
