It is currently Sun Jul 20, 2025 6:29 am
 Post subject: RE 13 cam specs
PostPosted: Thu Aug 21, 2008 6:21 pm
Has any one got all the details/specs on the RE13 cam shaft.
And if posible info on dialing in this cam shaft.
Cheers Tony.
PostPosted: Thu Aug 21, 2008 7:56 pm
RE13 is listed in here, scroll down...
http://www.mlmotorsport.com/index.php?o ... topic=11.0
PM me for more info.
PostPosted: Thu Aug 21, 2008 10:54 pm
fairly typical wear pattern that I find on strip down of a road engine equipped with 1.5:1 ratio rockers. Typically mileages from 10,000 to 50,000 depending on use and oil changes etc.
F*CK !!
PostPosted: Thu Aug 21, 2008 10:57 pm
This space for rent
Holy cow! "Fairly typical"!? Yoinks! :shock:
PostPosted: Fri Aug 22, 2008 7:09 am
I had a VP3 Camtech cam that looked like that after 45,000 miles with 1.5 rockers. Valve lift on 2 valves dropped from .470" to .270". But many other lobes were still fine, go figure... :?
I reckon it was a combination of the oil I was running, the pointy VP3 lobes, and the cam hardness or lack thereof.
RE13 cam lobes have a nice big nose radius, from what I've seen they don't wear much, 1.5 rockers or not.
