It is currently Sun Jul 20, 2025 6:11 am
 Post subject: Speedo cable and SC12
PostPosted: Thu Aug 28, 2008 3:14 pm
Does anyone else have a problem with Ben's SC12 kit obstructing the speedo cable at the speedo end? It's a bit annoying having no speedo :).
PostPosted: Thu Aug 28, 2008 3:26 pm
Milatsmadmini
ya dont need a speedo to tell how fast your going :roll: a tacho, oil pressure and a rope will suffice :lol:
PostPosted: Thu Aug 28, 2008 8:11 pm
The cable should run under the carby to SC manifold without too many hassles. Will be a pain to fit with the manifold on though.
4efte powered Clubman
supercharged 998 race car
PostPosted: Fri Aug 29, 2008 11:59 am
no speedo cable for me - used a bike speedo off the rear hub, (this is mainly because i forgot to change the drive and my mini cable won't fit the metro box)
backyard performance............. Aint it the best
PostPosted: Fri Aug 29, 2008 12:05 pm
I use a GPS, the speed reading on that is better than a speedo..... And I don't get lost!
Also, speedo is not hooked up......
PostPosted: Fri Aug 29, 2008 12:41 pm
thats where mine goes on the sc kit was a challenge to get it on but it made it
Enjoy Chris ;)
PostPosted: Sat Aug 30, 2008 12:00 am
hehe thread the needle
you'll need a speedo with all that boost
PostPosted: Sat Aug 30, 2008 1:30 am
My SC12 was into an 850, and can honestly say I had absolutely no issue fitting the speedo cable past the blower...
Carl
PostPosted: Sat Aug 30, 2008 10:40 pm
I didn't have any issues with my speedo, just pushes under my carby and down and it.
I will say though that the cable was attached when the engine was put in last.
