mickmini wrote:
So there is no difference in the ratio of master to caliper or wheel cylinders. No difference in the ratios means that there should be no difference in pedal feel and effort.
There is no difference in master to caliper ratio you are right.
What you need to understand is that the bore for a specific car's master cylinder is based on achieving X amount of pressure (psi) to the brakes (can be different for front/rears), based on the pedal configuration.
You've changed the pressure to the front/rear brakes by removing the mini rear limiting valve and swapping it for an adjustable tilton brake proportioning valve.
More fluid is going to the rears which means there is further to push the fluid, which is why (in your case) the pedal has longer travel.
Have a look at the graph on the tilton manual - it tells you that from an input of 1200 psi, you can range it from 500 - 1100 psi (41.6% - 91.6%).
It's not 100% adjustable and what I think you are finding is that even at it's lowest setting (41.6%) it is pushing too much fluid to the rear.
Solution - upgrade your master cylinder or add back the original mini rear limiting valve or remove your tilton prop. valve.
I'm about to change master cylinders and add a lever-type tilton prop. valve on my race mini - i'll let you know the results, but I plan to keep the original mini rear valve intact.
My goal is to improve pedal feel with my 4 pots and see if I can improve braking via the prop. valve.
