It is currently Sat Jul 19, 2025 11:02 am
PostPosted: Sun Aug 16, 2009 7:22 pm
I was thinking of making a helicol idler gear with timkin bearings like the link below but helicol
out of an existing gear
Purpose to eliminate the idler washers
So what do you think
Kiwiinwgtn
PostPosted: Sun Aug 16, 2009 7:30 pm
Ah, you want one like this then? :P
(this one belongs to justminis).
KG Engineering in Melbourne made it.
Company now gone kaput, but hey, it's possible to do. I suspect they made a new gear though, not machined out an existing idler.
PostPosted: Sun Aug 16, 2009 7:37 pm
Hi Kev
Yep, thats the one
I need to pull my engine down to re do the seals and repaint after the fire so i thought while its apart i would make some improvements.
Has any one tried the gears any issues
Bernard
PostPosted: Sun Aug 16, 2009 7:48 pm
Fire Pic
PostPosted: Sun Aug 16, 2009 7:59 pm
Hi Bernard
KG did make a new gear for that set up. My first attempt (1990) was with an original gear machined to suit the timken set up. It worked under a 1380 for quite a while but the centre step in the gear for the bearing races was too thin (my bad) and did break. The KG gear has a substantial centre step. While I have not done another original gear, believe it is entirely possible to use an original gear provided the centre step is sufficient.
Steve
Steve
PostPosted: Thu Aug 20, 2009 12:46 am
The other alternative is to use a std gear and shaft. Machine the shaft down to 5/8" and fit the taper roller outers to the caseings. The brg in the flywheel side is in a fixed postion but the one in the gear box case has 3 5mm grub screws that push on the outer to give the correct pre-load for the brgs.. With the brgs further apart the whole assembly will take more load and the brgs have less twisting load on them.
www.minisprintgt.com
PostPosted: Thu Aug 20, 2009 4:28 pm
HI
Great idea, do you have a picture of one
What bearing would you use
Thanks for the reply
Kiwiinwgtn
