I was going to say that the A Series, being a small engine, would've had indirect injection and pre-combustion chambers.
You'd still want glow plugs, though. My 2005 2.5L Common Rail Variable Vane Turbo Diesel still has Glow Plugs, and a little light on the dash to tell me when they've warmed up (only takes a couple of seconds). So, that would mean you'd actually need 8 holes in the head..? 4 holes for glow plugs, 4 for injectors.
If you were to do a TD A Series... Wouldn't you use a 1275 head?
I mean, the turbo/blower exponents amongst us all seem to end up going that way. Plus, it's a small combustion chamber, so it's easier to jack up the compression ratio.
My big concern would be the 3 bearing crank. Everything else can be upgraded, but it's pretty hard to add extra bearings to the crank.
That said, I'd love to see someone with heaps of time, skill, equipment and money try to do it.
Or even just someone with bits of those, and lots of determination.
