It is currently Sat Jul 19, 2025 10:57 am
PostPosted: Tue Sep 08, 2009 1:36 pm
i've decided that i should get my motor and gearbox rebuilt.
the motor is a bog stock 998cc. so far the conclusion has been made that i need some headwork, a different cam, carb.
just curious on what kind of cam, carb etc i should be looking at?
im entrusting the work to a workshop here in adelaide and they have asked me what i want done. :roll: im looking at something reliable but most of my driving is in the hills area so i dont want to be struggling to much.
any advice would be much appreciated.
thanks
simon
PostPosted: Tue Sep 08, 2009 3:14 pm
Have a chat to GR about a cam. RE13 has been a fav in the past, but chat to him as he has some new ones that MAY suit you better??
I'd use an HS4 SU (1.5") on a nice manifold like a Mini Spares or even better a GR manifold.
If you are going to get head work done, make sure you have yourself a 12G202 or get one if you don't (it's a head off an 1100 and better suited to modifying).
PostPosted: Tue Sep 08, 2009 9:04 pm
keep watching this thread
http://www.ausmini.com/forums/viewtopic.php?t=56835
PostPosted: Wed Sep 09, 2009 7:56 pm
The Forkmeister
Mate, i'd get a 202head(1100) have it serviced and get it shaved say about 40thou to get the compression up, go 80 or 100 thou bigger bore , get GR to grind you up a nice RE266 cam and get the lot balanced. You will end up with a nice 998 witch sould be pretty reliable and easier to drive in the hills. :)
May the fork be with you.
