It is currently Sat Jul 19, 2025 9:53 am
 Post subject: Electric water pumps
PostPosted: Thu Nov 26, 2009 7:12 pm
Does anyone have any pics or information on installing an electric water pump on a mini?
There is a lot of talk about them being on miglia minis but doesn't seem to be any kits around.
ie how where to mount them, adapters for the old pump mount etc....
68 Mini
70 Moke
PostPosted: Thu Nov 26, 2009 9:18 pm
I fitted one to my clubman when they were first released, was pretty good
remove the pump and make up a plate with an outlet in its place
I used a radiator from an AE82 corolla tucked in behind the grill (the pump went where the rad normally sits and the stock rad didnt work behind the grill)
I used various bits of radiator hose and alloy pipe to plumb it all
overall I think it was a pretty good mod, gave it a fair bit more power at the wheels and didnt get hot ever
PostPosted: Thu Nov 26, 2009 9:38 pm
whats the advantages over the mechanically driven ones. I mean just buy a high flow impeller water pump and you'll be sweet. the mechanical ones have worked for half a century. the electric ones would be more expensive, and probably more prone to breaking down...just my view... yes im a cheap arse :lol:
PostPosted: Thu Nov 26, 2009 9:45 pm
Yep fair call about the mechanical pumps.
This is for a dedicated race car. The water pump does a fine job until the race is over, then due to decreased revs, water flow slows down and I get a lot of heat soak into the block. Therefore if i go electric, revs don't come into the equation, another bonus is a bit more horsepower!!
I could make a plate up but was just curious to see some pics on what other people have done. No point trying to re-invent the wheel.
68 Mini
70 Moke
PostPosted: Thu Nov 26, 2009 10:34 pm
if you don't mind BMW parts something like this may work
http://cgi.ebay.de/ws/eBayISAPI.dll?Vie ... K:MEWAX:IT
Rover 214 atm ....
PostPosted: Fri Nov 27, 2009 9:27 am
With the miglias, cost is not usually a major consideration so many run Meziere pumps and custom blanking plates with the pump mounted as low as possible.
Others have just removed the impeller from the standard water pump and blocked the shaft hole, and used a variety of Bosch/FIAT/etc pumps with a lot of success for less $$$. Thermostat needs to come out too, ideally replaced by an electronic controller.
Do you want to borrow a Davies Craig EWP 80 to trial Darren?
PostPosted: Fri Nov 27, 2009 9:36 am
Found a pic:
Of course they use front mounted radiators & thermo fans for better cooling too, so no need for a crank driven fan.
PostPosted: Sat Nov 28, 2009 10:33 pm
the miglias also dry deck the head - ie all the water galleries between the block and head are blind plugged in each. The water then flows into the block at the hole where the pump used to be, out of the welch plug hole above the flywheel housing and into the head through a hole made in the end of it, then out to the radiator through the normal thermostat hole.
a la
Some run to a header tank from the thermo housing
all this to say that the miglia guys are doing a bit more than kjust adding an electric water pump :)
you can get a kit from swiftune to fit the hose between the block and the head
http://www.swiftune.com/Product/361/dry-deck-kit.aspx
michael
