It is currently Sat Jul 19, 2025 8:01 am
 Post subject: Excel seats
PostPosted: Tue Dec 22, 2009 5:41 pm
Ive seen some people say they are using excel seats in there minis.
Just wondering if you could explain how you fitted them possibly with pictures?
In a roundy btw.
And as I understand in vic there is no need to engineer if im using the standard brackets.
PostPosted: Tue Dec 22, 2009 11:31 pm
I think mounting the seat to the mini bracket may be a bit hard seeing as they are completely different. You most probably will need at least a customized bracket between the mini mount and the excel mounting point, this will be the item that needs to be approved, if you understand what I mean. Also how are you mounting the rear of the seat :?: again that will need approval :wink:
Good luck with it all though.
P.S. This topic should probably have been put in "mini chat" seeing as it is not a question about A or A+ engines, you will probably get more responses in mini chat as well :wink:
