It is currently Sat Jul 19, 2025 7:55 am
 Post subject: SU accelerator setup
PostPosted: Tue Dec 15, 2009 6:34 pm
hey,
first time setting up an SU (previously had a weber)....
Am wanting to find out where/how to attach the accelerator :)
ive drawn on a picture...
green line = accel cable
Red = spring, where do i attach the spring to?
blue = what do i do to that bit?
thanks
James
'75 windowless van
~LOLA~
PostPosted: Tue Dec 15, 2009 6:39 pm
Red bit- no extra spring is used. There is a torsion spring on there already.
Blue circle- you need a cable anchor bracket (for that carby) to hold the throttle cable and return spring.
PostPosted: Tue Dec 15, 2009 6:50 pm
Thanks Doc :!:
would you be able to explain the cable anchor bracket a little bit more please?
'75 windowless van
~LOLA~
PostPosted: Tue Dec 15, 2009 7:48 pm
It's a plate with a 45mm hole in the middle, has 4 bolt holes to fit your carb, it sticks upwards to hold the cable shroud and downwards, where it holds the return spring.
Check any stock Mini with an SU and you will get the idea.
You can butcher an HS4 one about to fit, but it's better to source the right one. These are a bit scarce now (mine came from Mini King, S/H.)
PostPosted: Tue Dec 15, 2009 8:17 pm
This space for rent
Your green line in the pic is for the choke cable, not the accelerator ;)
PostPosted: Tue Dec 15, 2009 8:27 pm
arhh ok thanks guys.
is their any other way around it if i cant get a cable anchor bracket?
'75 windowless van
~LOLA~
PostPosted: Tue Dec 15, 2009 8:58 pm
You would have to make something up to do the same job.
PostPosted: Wed Dec 16, 2009 12:04 am
blue ringed thing is the throttle,,, green line will be choke cable
& yes, you`ll need a cable retainer (inner & outer) inner for the lever circled in blue & the outer cable retainer needs to be anchored by a manufactured bracket of some sort, with it`s alignement & "swinging" correctly in-line with the throttle lever (circled in blue)
you`d probably want to "un-Adjust" the throttle strop screw a tad before setting up the throttle cable tho,,, then re-adjust the throttle stop for correct idle
PostPosted: Wed Dec 16, 2009 8:35 am
I just replaced my yesterday after it broke real easy to do
make sure you adjust the length going trough the two nuts that told
it otherwise it might not be in an idle position causing the car to rev
high
:? dunno if that helps you might already know that
Last edited by mini is my ride on Thu May 06, 2010 8:37 am, edited 1 time in total.
PostPosted: Wed Dec 16, 2009 8:46 am
thanks for your help!
now just need to find the part from somewhere :wink:
'75 windowless van
~LOLA~
PostPosted: Wed Dec 16, 2009 9:49 am
so something like this -
http://www.minisport.com.au/prod1463.htm
but without the heatsheild cause it wont fit with the sc12 on...
and i was just having a little play around with the throtle and choke parts, the choke has a return spring but the throtle dosn't, is that right?
james
'75 windowless van
~LOLA~
PostPosted: Wed Dec 16, 2009 9:53 am
This space for rent
The choke has a return spring built into the mechanism, the throttle does not. You need to fit a return spring to the throttle, not to the choke ;)
PostPosted: Wed Dec 16, 2009 10:00 am
cool as thanks sgc
'75 windowless van
~LOLA~
PostPosted: Tue Dec 29, 2009 6:51 pm
There are some bad pics on my build diary
http://www.miniaddicts.co.uk/forum/show ... 12&page=20
998 SC12 61atw
