It is currently Sat Jul 19, 2025 7:19 am
 Post subject: Speedo and Tacho
PostPosted: Sun May 16, 2010 1:48 pm
Hi Guys,
Felt the need to spread the word on a small issue I had on completing an engine rebuild. Since I'd converted to elec ignition, I needed to get my (late clubman) tacho sorted to run from the new signal. A calibration wouldn't go amiss, either. And while I was at it, the speedo was a bit lazy from 80k up.
Easy sorted, I thought. Booked the car in with a certain gauge specialist in West Heidelberg (we all know the one) and away we went. :)
When I got the car back I knew by the time I was shifting into second gear that the tacho was woefully out. :( By the time I shifted into third I knew the speedo was worse than it was before. :evil:
Being pressed for time, I drove home and rang up the next day to raise the issue. The excuses flowed like water. No offer to try to sort either issue was made.
Now I didn't go back there to rant and rave cos my blood pressure is high enough as it is. Suffice to say, I've forked-out $650.00 of my hard-earned to an "expert" and ended up no better off for it. :evil: :!: :?:
To add insult to injury, I managed a better tacho calibration with a half-hour of tinkering at home with a multimeter and a couple of tiny screwdrivers. :roll: Pathetic.
OK. Nuff said. Be warned. Apparently the guy in Ringwood is very good. We'll see.
Caring about your job is for people without lives.
PostPosted: Sun May 16, 2010 1:52 pm
yes the guy in ringwood is good and so the guy on mt alexander rd flemington. {speedscreen}
