It is currently Sat Jul 19, 2025 1:29 am
PostPosted: Thu May 13, 2010 6:07 pm
bit pricey to buy, let alone the cost to ship it over here.
but a good setup to copy for all interested especialy if you have 13" wheels.
http://www.superfastminis.com/ULTIMATE%20REAR%20COILOVER%20SUBFRAME.dwt
1969 Blue Mini K, 1330cc, Weber 45, polished aluminum roll cage, Race seats, 4 point harness, full rewire incorporating 8 fuses, 6 relays and new headlights :) just needs tyres front shocks and a windscreen til re-register
PostPosted: Mon May 17, 2010 9:19 pm
That idea has been around for a fair few years. Great for weight reduction but may be illegal on Australian roads, although you could get it engineered and passed that way.
PostPosted: Mon May 17, 2010 11:21 pm
I wouldn't bother with that particular one. A 20% weight loss isn't anything to write home about. and those discs are far to big for a fwd car. Rear discs bigger than the fronts never looks to crash hot to an engineer.
Have a look at the force racing ones, that's a nice looking rear beam and trailing arms.
Simplify and add lightness
PostPosted: Thu Jan 13, 2011 7:41 pm
same but without the disks on it, so $1206.51 makes it cheaper but still needs postage.... thought about it, but as has been said, big brakes at the back arnt good (unless your in reverse) you can get 7" disk kits to fit on, which if you have the big bake kit on the front (9") then the ratios would be a bit closer, or maybe put a bias valve in to make the fronts do the work....
http://www.minimania.com/web/Item/MT360 ... Detail.cfm
Users browsing this forum: No registered users and 29 guests
