It is currently Fri Jul 18, 2025 9:49 pm
PostPosted: Thu Oct 06, 2011 7:03 pm
I'm building a N/A, 1360, A+ series, BMW K100, 8 valve donk and I'm trying to decide what comp ratio I should be going for and what pistons I should buy :? Any ideas or suggestions will be appreciated.
Currently I'm planing on wedging the crank and re-using the standard rods. I'm also looking at getting a steel lightweight f-wheel which I might end up getting from the UK if I can't find anything locally that will be as good and as cheap.
PostPosted: Fri Oct 07, 2011 9:59 am
11:1 comp ratio will be fine on these things in N/A form
& Hypertechs or our own design JP piston will get you there quite handsomely :-)
but the hypertechs are far cheaper than the JPs
so hypertechss are probly the go
PostPosted: Fri Oct 07, 2011 3:13 pm
Hey Miniman do the JP's already have the valve cut outs ?
is there any benifit over the hypatecs ?
Beanie
I am the son of the STIG
HOTBRICKS
http://hotbricks.org.au/
'65 NCF MINI.....
PostPosted: Sun Oct 09, 2011 7:11 pm
no, the JP`s come with just a dish,,, you`d need to fly-cut them to suit your application,,, 8V or 16V dependant
& they have a thicker crown, top ring is slightly lower on the piston than the hypertechs, so if you were chasing lower compression (Eg: turbo or supercharging) then there is Plenty of meat to rip off the top , still leaving a very strong crown
thin rings too so they flex rather than just break
