It is currently Fri Jul 18, 2025 1:54 pm
PostPosted: Mon Apr 29, 2013 7:11 am
Was wondering if anyone has had any first hand experience with this med intake kit for a 45 webber, at the moment I'm running a redline manifold 3005 and a ram flow filter.
http://www.med-engineering.co.uk/catalo ... ake-system
PostPosted: Mon Apr 29, 2013 6:38 pm
I've got one of those set ups on my race car. I haven't done any dyno testing yet, so cannot validate their claims of increase HP. What I can tell you is with a six inch manifold, I can't get the filter off, and I'm running a fairly large air box
Member VMCI #19
PostPosted: Tue Apr 30, 2013 10:16 am
If you don't have a weber box built into the firewall, you won't have much choice in the matter...
FYI see discussion about weber boxes: http://www.ausmini.com/forums/viewtopic.php?t=81275
Lillee - 1969 Morris Mini K
PostPosted: Tue Apr 30, 2013 7:29 pm
Ramflo filter works fine on a 45 once you bin the Lynx foam and put a Unifilter LNX400 pad in it instead.
My 1412 made the same 114HP on the engine dyno (using a 45 Dellorto), both with and without the Unifilter pad in.
Users browsing this forum: Bing [Bot] and 6 guests
