It is currently Sun Jul 13, 2025 12:12 am
Post new topic Reply to topic  [ 96 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7
PostPosted: Fri May 09, 2014 5:39 pm
Beanie wrote:
How Much seat preassure did you have , and what are you aiming for now
the build before last didn't have enough seat pressure and there was evidence of valve bounce on the cam, so I got some new springs (aea526) and used them with MK1 valves on a MK2 head - turns out I would've had north of 120psi... now I have spot on the spec of 83 (which is what it should be at 1.35")
PostPosted: Sun Apr 17, 2016 3:41 pm
I've taken it off for now - and given the car did 48 motorkhanas today, I'm glad I did... it didn't miss a beat, there's no way it would've handled that with the blower on it.
It was great fun to drive with the blower, but no fun to own, aside from being illegal without an engineers certificate - too temperamental, too unreliable, too much mucking around to get it to run right, too much time spent on it that would be better spent on other things (like trying to do my Honda conversion). Maybe one day I'll build a 2 piece manifold that'll let me run an intercooler and inject on the hot side direct into the ports, but not for a while. All the gear is in a box in the shed now.
I've put a single HIF44 on it, and kept the megasquirt running the LS1 coils. I still have the 3.1 diff in it, which makes it very lazy to drive, so I'll put the 3.44 back in before Hay
All the work I put into trying to get it to run nicely with the blower & injection has made it the sweetest thing to drive with a carb, it just runs beautifully...
PostPosted: Tue Apr 19, 2016 4:39 pm
I hear ya.
Only now (after 4-5yrs of off and on tinkering) am i happy with mine but it is still not as easy to drive as my neighbour's Mk2 1275 with twin 1 & 1/2 SU's.
The Mikuni is very good and a good bump up in power but driving style has to be altered.
No need for this type of compromise with NA. It was fun watching you tinker though so all is not lost.
Draw through in all it's simplicity can be a complicated bitch.
1310 SC 1969 Morris Deluxe - 15psi boost
1293 1968 Morris Deluxe Miglia - 45 Weber
HSV Maloo Z Series - Comp Cam - 300rwkw
Ford DF LTD - 5Ltr
PostPosted: Wed Apr 20, 2016 7:17 pm
No SC will make much easier for the ladies to drive.
I'm doing something similar in that I have taken the silly cam out and put a sensible one in so Aiden can drive it comfortably.
Aaron
PostPosted: Wed Apr 20, 2016 8:57 pm
Aaron
of course - it's his 1st Hay too - excited??
PostPosted: Mon Apr 25, 2016 12:34 am
He is! Cams are taking there sweet time about sending out his licence though, so it's holding things up a bit. Hoping to get him through two Motorkhanas before Hay, One being a State round!
