I run a motor very simular to kevs, but less compression, bit more cubes, but less headwork, bit less power, although im sure some of that is to do with Kevs fastigeous engine maintenance.... Anyway i did originally have a cooler on it but after a nasty cranksnapping incident i needed a rebuild, Graham Russel told me not to waste my time with an oil cooler (and asking for trouble using the old one, nomatter how well i flushed it out), and definately not to bother with fancy (read: expensive) radiators, he also told me my car would likely run too cool with the minimatic heater core i had installed (like kevs) so i pissed it of, before this i was driving blind (guageless) so i had no idea how hot the car was and what my oil pressure was doing.... Incidentally, when i quizzed him about thermo fan settings for a customer the other week he mentioned he cant get cars to run hot enough when using thermo fans
So I just got my stock radiator flushed and it is fine, having said that though, after a few hours of hard driving on the weekend my oil pressure dropped quite a bit (i currently run HPR30 oil btw), but the temperate was ok, so on a worked street motor that will see some hard driving (like track days, and serious sunday runs, lke me, kev and the crew have
)i would probably stick a cooler on it, just to be safe..... Although mini's run hottest usually in traffic, and i doubt a cooler with do much good then, without any air rushing through it, what im saying aswell is coolers wont fix an inadequate cooling system
Sounds like your motor doesn't really warrant a cooler, and as mentioned it could be considered a little insane to put a second hand cooler on your fresh 1275, there is no way to recondition coolers aside from flushing them out... The risk isn't worth the benefit in my opinion
But thats all this is. my experiences and opinions
G
