It is currently Sat Jul 19, 2025 6:55 am
PostPosted: Fri Sep 03, 2004 12:08 pm
yeah tell me about it! Maybe I should auction off the Dellorto eh Kev? and get 3 back! :wink:
PostPosted: Fri Sep 03, 2004 3:16 pm
that guy is on some serious drugs but the clown who is going to purchase is the one who really needs his head checked :shock:
PostPosted: Fri Sep 03, 2004 5:59 pm
head checked..??
But I thought that if I bought that $700 webber it would go well with my $34,000 Mini...
:roll: must be wrong
PostPosted: Fri Sep 03, 2004 6:43 pm
hahahahahahahaha the sad thing is that there probably is someone out there thinking that thought...... but they are serious tho :shock:
PostPosted: Mon Sep 06, 2004 5:46 pm
OMG $606!!!
Check out the buyer's history! He just bought the Hi Ho Silver clubman for $900! the carb is worth 2/3 of the car!!! *faints*
PostPosted: Tue Sep 07, 2004 8:26 pm
haaaaa ha ha... thats dumb...
now... for a serious question. I have also picked up a webber (lot nicer than that one and only cheap..!) but have a question. See pics at the end of this page
http://www.cardomain.com/memberpage/680606
I have 3 inlet pipes currently (first pic) but the webber only has two inlet pipes. What happens with the third (blue arrow in the first pic)
:oops: I am sure that there is something I am missing...
PostPosted: Tue Sep 07, 2004 8:33 pm
Ah OK I think you mean what happens to the exhaust manifold, which is combined with your inlet one.
Yo get a hacksaw or angle grinder and cut the inlet off the exhaust. :P Save the exhaust part.
OR, put it on the shelf, then go buy a freeflow or LCB manifold (headers) & exhaust system, which is what most peiople do. :wink:
PostPosted: Tue Sep 07, 2004 8:37 pm
when you say headers... thats extractors yes..?
Which would be done first, extractors, then the webber, or webber then the extractors. I am getting both done.
PostPosted: Tue Sep 07, 2004 8:51 pm
You will save on gaskets if you do both at the same time. The problem is your current manifold is one piece, meaning that the inlet and exhaust are joined. Hence, to fit the weber and keep your current exhaust, you have to cut the original manifold, and if you want to keep your carb and change your exhaust you would also have to cut the original manifold. It is much easier to fit the extractors at the same time as the weber, then you don't have to cut anything!
PostPosted: Tue Sep 07, 2004 9:02 pm
OK... so before I waste my money...
If I take the webber to a place with my extractors then can they do all this in one hit?
The exhaust is then just an extension of the extractors isnt it..??
PostPosted: Tue Sep 07, 2004 9:09 pm
Yes you'll want to do it in one hit, I'm sure an exhaust shop would bolt the weber on, but I wouldn't expect them to do more than that, you'll have to take it elsewhere to tune it (assuming it drives okay with the weber on before tuning you never know).
Yes, exhaust is just an extension of the extractors, however if you still have the stock exhaust system you'll want to upgrade it, since the extractors will likely have a larger pipe size than your current system, and the OEM mufflers aren't very good, you'd be better off with a straight through muffler (which don't cost much).
Anto.
PostPosted: Wed Sep 08, 2004 2:18 am
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
i have a 3 into 1 extractors here 40 bux
makka
PostPosted: Wed Sep 08, 2004 5:30 pm
:shock: what diameter is the pipe..?
will they fit 998... what condtion..? If they fit and their good, I will get that with the roll cage bit I have been too fu*king lazy to get :wink:
I still want that by the way. just been a slack ba*tard
PostPosted: Wed Sep 08, 2004 7:17 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
no worries
makka
PostPosted: Wed Sep 08, 2004 11:01 pm
:?: what diameter is the pipe..?
will they fit 998... what condtion..? :?:
