It is currently Thu Aug 14, 2025 1:25 am
PostPosted: Tue Nov 21, 2006 3:45 pm
My daughter and I are doing a restore on her clubby - got carpets from Knox and i was a bit concerned about the bits that go over the front wheel arches. Your "How To" is a big help.........thankyou.
Hooroo
Rod Image
PostPosted: Thu Sep 01, 2011 3:39 pm
Replying to a very old thread, I know.
To remove the accelerator pedal to fit the carpet.. mine’s got nuts on the inside of the car (from memory) are these captive bolts or do I have to get under the car as well and do it from both sides? I know a mini’s small but not sure if I stretch around from inside near the acc pedal, to up under the body near the rack…
Suggestions?
PostPosted: Thu Sep 01, 2011 4:31 pm
mine had captive bolts. i think they are welded to the floor panel actually.
So no need to reach under the car
Dusk Blue
1964 850
PostPosted: Sun Sep 11, 2011 8:51 pm
mine had one that seemed captive and the nut undid,
the other bolt just span on itself.. so i cut the carpet to fit around the bracket... the impatient one i am..
now it looks like i'm going to have to find the heads of those bolts anyways as the bracket seems to have a bit more movement than i'd like..
