EAB wrote:
the inside diameter of the pipe matches the max diameter of my already ported inlet ports.... so it may get that little kick up in the air flow that it will need to remix the mixure again without constricting the flow too much.
I'm keen to know how it goes.
Some thing that could be worth trying......grind a crescent shape out of the
bottom of the manifold ....say about 3mm deep and 10mm long.
Imagine the fuel dribbling down the outside curve just like water runs
slowly up your windscreen in the rain even though you are doing 100kmh.
As this fuel approaches the port it gets whipped in as big globs.
Now we have this little dam that traps the big globs but.......because of the increased turbulence
and the sharp edge of the port, the fuel gets whipped (sheared) up into fine droplets then into the port.
This what I am going to do a 8.5" twin manifold for my 1100.
There is nothing new about this practice.....but the good thing is, it's unlikely to slow the flow and you can do a before and after and measure any difference.
