It is currently Sat Jul 19, 2025 7:33 am
Post new topic Reply to topic  [ 41 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Thu Oct 15, 2009 11:04 am
yep,,, we can have one made for you no problems
we can even have the rods "Straight" as in --> the center of the piston centered to the center of the big end if you like... no off-set
it`s only money :-) :-) :-)
How many would you like?????
PostPosted: Thu Oct 15, 2009 3:26 pm
sports850 wrote:
As something of a hypothetical question here , while I know you can make pistons and rods (if you have the equipment and skills or can pay someone to do it for you) , would it be possible to turn up a super strong crank on a lathe out of high grade steel ?
Sure can, people like Sainty Engines make cranks (V8 ones) all the time. They CNC mill theirs instead of turning, it's much quicker metal removal.
I got a quote many years ago for a nice billet of EN40B, but it was worth a small fortune even then. Even before I could start turning.
And you would want a serious bigass lathe for this, or it'd take a million years. Not yer average 6 or 9" centre lathe.
On the other hand GR can fix you up with a nice 4140 nitrided 8 counterweight S race crank, made in Melbourne, for around $4K. Hey it's only money...
:lol:
PostPosted: Thu Oct 15, 2009 3:43 pm
I was thinking more of an "ultimate" 850 crank though , I know there are options for 1275 but a nice strong crank and set of rods setup to use bike pistons of appropriate size so it all works out close to original bore and stroke ....
PostPosted: Thu Oct 15, 2009 4:23 pm
How about cutting and shutting two blocks together to make an inline six? 8) (seeing how we are now fast approaching fantasy land)
PostPosted: Thu Oct 15, 2009 4:44 pm
:roll: why make a straight six where you wouldn't be able to fit the radiator when for the same amount of work you could make a V8 ...
More a hypothetical than anything but a seriously strong 850 crank that would fit in a standard block (cheap and plentiful) would be great .
PostPosted: Thu Oct 15, 2009 5:02 pm
A V8 is actually a lot harder to make. There is the big problem of trying to fit two con-rods on one crank journal and keeping that within the length of the existing block.
An inline six would fit quite nicely in a Morris 1100. :wink:
PostPosted: Thu Oct 15, 2009 5:55 pm
Righty Oh, back on topic , lets start crunching some numbers to give us a true picture of what we are trying to do ,
my first attempt at calculating a possible result using the the parts I could find was interesting, Melling cylinder sleeves , using their stock 2.7950 inch bore Sleeve would require a 0.381 bore ( 15 thou ) and with the sleeve thickness 3/32 inch 2.3813mm would give you a 68.6117 mm 2.7012 inch bore, so 1202 cc
Now using a forged flatop 69mm piston, we now move to a bore of 69mm and stroke 81.29mm - 2.7165 inch and 3.20 inch , so 1215 cc 74.185 cubic inch . Now obviously with flat top pistons like these , some careful thought is needed for the final compression ratio in regards to head modifications.
[img][img]http://img185.imageshack.us/img185/9484/gre104buggati.jpg[/img]
So now its just matching it with longer and stronger conrods and a suitable crank and we are getting close to the longer lifespan 1275 block according to my theory , true it is with reduced capacity , but still with good torque. :D
.[/img]
( Thank,s Mr Green , I couldn't find a good photo of a 69mm 4 stroke motorbike piston and the Lambretta Scooter piston being 2 stroke doesn,t have oil rings but it was a good photo, this a Bugatti piston )
PostPosted: Thu Oct 15, 2009 6:12 pm
Dean, nice pistons there, but you'd better find some with oil rings, or there'll be tears before bedtime... :lol:
PostPosted: Thu Oct 15, 2009 7:58 pm
quite a number of 6cyl bike engines out there Morry,,, Benelli & kawasaki & triumph to name a few,,, the kwaka 6 would be the most avaliable & cheaper than the others tho
PostPosted: Thu Oct 15, 2009 10:09 pm
I did finally get a better photo of 69mm motorbike pistons, yes , with oil rings :roll: , it is quite a common overbore size in motorbikes so there are choices available.
It is certainly an interesting exercise so far, a sleeved 1275 with a 69mm bore / 2.7165 inch and stroke 81.28 mm / 3.20 inch , 1215 cc 74.185 cubic inch :D
[img][img]http://img508.imageshack.us/img508/1874/juegopistonessanglas400.jpg[/img][/img]
PostPosted: Thu Oct 15, 2009 10:43 pm
Psst - Mr Asparagus - 1215 Cubic Centimetres (cc), not Cubic Inches (ci). :wink: Of all the people on this forum Mad Mr Read's the closest I know about to getting to 1215ci in a Mini, but his Rover V8 is only something like 215ci (3.5L), 241ci (3.9L). :twisted:
PostPosted: Thu Oct 15, 2009 11:13 pm
I know, I know :P I wrote it arse about , 74.185 cubic inches, 3.715 cubic inches LESS than standard !
And thats the whole idea !
Less is more for longer !
PostPosted: Fri Oct 16, 2009 3:17 am
with the bike pistons honda cbr 600 f3 had 67 std with 68,69 o/s. the f4 was 69 std and has 70, 71, 72 o/s then the 900 continued from that size in bore ,but heights gudeon pin dia are different.
When I went thru the exersise before it meant that the rods had to be quite a bit longer.
Now here is a interesting one for the crankshaft. Search for a sectional constructed crank shaft and where they are used. One application is in aircraft engines.
As for billet ones I made 4 up for john mc cormacks formula 5000 in 1974. He was the first bloke to use the p76 engine in one. It is one hell of a job doing them on a mill and lathe.
www.minisprintgt.com
PostPosted: Fri Oct 16, 2009 4:27 pm
Ahhem,,, :-) it`s actually ---> 4.7litres thank you :-) :-) :-)
But Shhhhh,,, don`t tell anyone,,, it`s our secret ok?
PostPosted: Fri Oct 16, 2009 6:26 pm
Thanks David , I could,nt find anything on those cranks , Google was not my friend this time, the only cranks that came up in searches was VW billet nitrided 84mm stroke crankshafts, ( of course they wouldn,t fit )
I was doing research on 69mm pistons and rang Wiseco and they were very rude to me when I asked about details on 69mm pistons and told them it was for a 1275 Mini engine, the conversation was cut short and they hung up on me :x . The main problem with ringing parts places and asking about 69mm size is that they have no idea about sizes , only Bike/Model/Part No !
