norton wrote:
It's important to check alignment of the 2 marks and sprocket centres with a straightedge, BEFORE putting it on the motor. I have pulled quite a few motors down where it was 1 tooth out.
1 tooth = 18° at crank... it's a lot!
so the motors ran at 1 tooth out ? must have been low on power, do you reckon they would run OKish both one tooth advanced AND one tooth retarded or one way only
I recently pulled down the 998 stroker that was in the wife's `pretend S' when bought, and found it was retarded by1 tooth. But it ran fine, we took it to Canberra and back twice, no power problems.
It's now been freshened up, and is in Baxter 850's van.
