It is currently Sat Jun 21, 2025 1:50 pm
Post new topic Reply to topic  [ 52 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Wed Apr 06, 2016 8:00 pm
I run 11.0:1 with my 282. I would not run more with 98 unleaded fuel in a road car.
PostPosted: Fri Apr 08, 2016 3:55 pm
Would the 282 camshaft be happy with standard lift rockers? Also would I have to be concerned about what valve springs I have? (as far as I know they are standard Cooper S ones)
Thanks
Michael
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Fri Apr 08, 2016 6:59 pm
Thanks
Michael
Standard rockers OK. Mine had standard rockers, head work, etc etc, made 127 hp and 114 ftlb.
Valve springs you will need to upgrade for sure.
Dyno results for mine and drmini here http://www.ausmini.com/forums/viewtopic.php?f=5&t=44857
My engine build thread here http://www.ausmini.com/forums/viewtopic.php?f=5&t=31567
michael
PostPosted: Fri Apr 08, 2016 10:10 pm
I use C-AEA526 valve springs. They are good for 8000 rpm and .497" lift with 1.5 rockers.
Stock Cooper S ones I would not use, you run the risk of spring bind, and rpm limit will be low.
PostPosted: Fri Apr 08, 2016 10:42 pm
+ 1 for the C-AEA526 springs. They got rid of the valve bounce in my last car. I got mine from Karcraft. My cam had an 8mm lobe with 1.5 rockers - so about 0.472" lift.
PostPosted: Fri Apr 08, 2016 11:56 pm
Is it worth a try with what I've got or will I for sure have a problem? I don't intend to go beyond 7000 rpm...
67 Deluxe
Dry suspension
PostPosted: Sat Apr 09, 2016 12:20 am
If you run a high lift cam with 1.5 ratio rockers you need to make sure you have plenty of clearance between the spring coils at full lift "crush". The C-AEA526 springs have one less coil so there would be little chance of these binding up. They are not that expensive. http://www.minispares.com/product/Classic/C-AEA526.aspx
PostPosted: Sat Apr 09, 2016 1:20 am
how do you run an in car VE check to determine if you have the right cam for your purpose?
PostPosted: Sat Apr 09, 2016 8:47 am
Springs soften with age and heat (they get shorter), do yourself a favour and change those springs.
1275 Cooper S gave peak power @ 5800 rpm, 7000 with stock springs would be pushing it even if the springs are new.
PostPosted: Sat Apr 09, 2016 10:25 am
With the RE282 you will definitely need to uprate the springs. They are relatively inexpensive compared to the damage you will do if you don't get them.
PostPosted: Wed Apr 27, 2016 1:55 pm
I've just ordered a RE282 camshaft and the CE526 springs so the project is going ahead after much humming and ahring! You only live once after all..
Anyone got a set of 1.5:1 rockers for sale?
Thanks
Mikal
67 Deluxe
Dry suspension
PostPosted: Sat Apr 30, 2016 5:10 pm
Anyone know what the rocker ratio is with the sintered A+ type rocker?
Thanks
Michael
67 Deluxe
Dry suspension
PostPosted: Sat Apr 30, 2016 5:43 pm
Thanks
Michael
Here are a few of the rocker ratios. Info was taken from various Ausmini forum posts and google.
PostPosted: Sat Apr 30, 2016 8:06 pm
You can fit offset bushes to the pressed steel or Cooper S forged rockers for a little more lift. Can't do this with sintered ones, they are unbushed.
PostPosted: Sat Apr 30, 2016 8:14 pm
Oh dear, I appear to have the 1.18:1 ratio ones. Guess they're no good for my purposes...
Open to suggestions..
Thanks
Mikal
67 Deluxe
Dry suspension
