It is currently Sat Jun 21, 2025 1:59 pm
Post new topic Reply to topic  [ 96 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
PostPosted: Thu Feb 23, 2012 9:30 am
I have an Innovate LC-1 in Brisbane Matt. On the bench right now. No gauge, just connects to the Megasquirt. If you have a sensor point in your exhaust, you can borrow it if you want.
M
PostPosted: Thu Feb 23, 2012 10:52 am
Looking very good Simon, can't wait to you get it on the road. My effort in EFIing my car (pales against yours ) is still going well, and I have done over 5000 Kms since installing it.
Give us a yell if you need help with the TechEdge or MegaSquirt stuff.
Jim
PostPosted: Thu Feb 23, 2012 3:23 pm
Can you run a 'swirl pot' under a front guard and run your efi to and return lines from that with an efi pump, and simply supply that with a single line and a traditional carby style pump?
Does that make sense?
PostPosted: Thu Feb 23, 2012 3:25 pm
Swirl pot = two small aluminium saucepans + mig or tig.
PostPosted: Thu Feb 23, 2012 3:53 pm
swirl pot won't actually help the issue - what happens when that fills up....
I think I'll just put a ball valve in the RH tank line, either shut it off completely, or use it as a restrictor
I had a brain wave about using an LPG solenoid to shut it off until the level in the left tank drops to half, then open it up until the level rises again... it'd work I think
PostPosted: Thu Feb 23, 2012 9:08 pm
My post but replace 'swirl pot' with 'surge tank'.
PostPosted: Thu Feb 23, 2012 9:16 pm
I know you probably don't want to tamper with a genuine RH tank if you need to make holes but ....
A t-piece in the return line to feed it to both tanks?
It seems like the simple answer.
michael
PostPosted: Thu Feb 23, 2012 9:31 pm
michael
yeah, it is logical - but as you said, I don't want to put holes in the RH tank....
I put a tap in it after work today. That'll do for now.
Hopefully my guru and I will take a drive tomorrow evening, me behind the wheel and him with the computer on his knees
PostPosted: Thu Feb 23, 2012 10:33 pm
I think it would be the same scenario. It would have to have return to the tank, so if it's still only plumbed into the LH side could cause the same problem.
Another Arduino project perhaps? :) I think I've got a few LPG solenoids kicking around if you'd like one...
Andrew
PostPosted: Fri Feb 24, 2012 10:01 am
nah, way too simple for that - 3 resistors and one little comparator IC, maybe a diode too
but I think the tap will work for now, then I'll go with our other idea
PostPosted: Fri Feb 24, 2012 8:16 pm
guru and I did some 'seat of the pants' tuning tonight, getting very nice, but the software on the laptop kept crashing :roll:
PostPosted: Sat Feb 25, 2012 12:05 am
It is a little complicated but modern saddle tanks run a float that controls a tertiary pump, this pump fills the other tank when one gets low.
Of course the simplest answer is to run a levelling line between the two tanks from the bottom.
PostPosted: Sat Feb 25, 2012 8:36 am
Never had a RH tank - why were they not fitted with this from the factory?
Another simple answer overlooked by the beancounters?
PostPosted: Sat Feb 25, 2012 8:45 am
They were fitted with a pipe between the tanks to self level. It works fine till you start sucking it out with a high pressure pump to feed injection and then block one of the tank vents and return all the fuel to that tank.
PostPosted: Sat Feb 25, 2012 9:11 am
I like the idea. You should get good cruse mpg. How is the setup looking at WOT?
998 SC12 61atw
