I would not like the gap to be less than .008" on a 1275's top ring. You need to allow for expansion when HOT.
Hastings top ones typically are .013"- .014".
[edit] I was not sure how so-called`gapless' rings work, however after reading this blog, it is clear one type works similar to the `Cord' brand rings used for re-ring rebuilds back in the 50s and 60s.
They do in fact have a normal gap, but there are 2 narrow section rings in the one groove, with their 2 gaps staggered.
A second type, Total Seal have the ends notched (only 1 ring in the groove) so the gap is Z shaped when assembled.
https://www.highpowermedia.com/blog/307 ... pless-ringalso see
http://performanceforums.com/forums/arc ... 39283.htmlhttp://015ef8d.netsolhost.com/TechPage. ... sPistRings
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
