Getting the engine running nicer. https://www.ausmini.com/forums/viewtopic.php?f=5&t=1267 |
Author: | sociallydisabled [ Sat Jul 24, 2004 9:58 pm ] |
Post subject: | Getting the engine running nicer. |
What are some ways i cant tune, make my engine run smoother? Im only a noob so i dont know too much so what would be some simple things i can do, and some things that will help me learn more about my car? ![]() |
Author: | 68matic [ Sat Jul 24, 2004 10:21 pm ] |
i recently found out by turning out both adjusting screws (the ones with springs around them) and slacking the choke and accelerator cables (and tighting it up TIGHT afterwards) the revs reduce heaps and the engine runs real smooth. there are things you also must look at, fuel mixture the nuts you turn at the base of the carby you can turn with your hand while engine runs turning it clockwise leans out fuel. make sure you do up the cables PROPERLY again. my accelerator cable stuck once and i was forced off the highway into BP at 40mph |
