731 camshaft
https://www.ausmini.com/forums/viewtopic.php?f=5&t=13041
Author:  willy [ Thu Nov 10, 2005 10:58 pm ]
Post subject:  731 camshaft
Okay with my A+ 998, i think i'll go the 731 route for cam.
Does it have a kinda lumpy idle?
I've been told its a road rally spec item, whatever that means :lol:
So yep, whats this cam like.
Any recommendations.
Its going with a weber, and i like my brap brap lumpiness 8)
Prices too?
is this cam available new?
or what is the cost of a grind on a standard cam.
cheers.
will.
Author:  supercharged 850 [ Fri Nov 11, 2005 1:46 am ]
The 731 would be my most favourite "budget" small bore cam. Yep, its as lumpy as your grandma's gravy :wink: Have a listen to Bob's morrie when he brings it to the workshop next. He has one in that.
Author:  drmini in aust [ Fri Nov 11, 2005 6:22 am ]
Yeah a 731 is OK in smallbores, I ran one for years- but there are better ones about now.
RE13 is the best sports one I've found. Way better midrange and top end.
Author:  gafmo [ Fri Nov 11, 2005 7:39 am ]
yer we had a 731cam for 2 years..and I liked it..replaced it with a RE13
Just that little bit better 8)
Still have the 731 here
Author:  Rodney [ Fri Nov 11, 2005 7:45 am ]
Umm.....sorry about the dumb question guys - I know there are all sorts of different cams but how do you tell one from the other???? Is it just experience??
Author:  drmini in aust [ Fri Nov 11, 2005 1:27 pm ]
Pretty much is. I've had about a dozen different cams in roadgoing Minis over the years.
All the cam grinders say theirs is the best, but a dyno is the great arbiter.
At our last Dyno day pretty much the top 10 (except for Ron's) all ran an RE13. :wink:
Author:  Rodney [ Fri Nov 11, 2005 8:48 pm ]
Thanks Doc. Does a RE 13 cam keep the valves open for a longer period of time or something???
Author:  willy [ Fri Nov 11, 2005 8:51 pm ]
Yeah and whats the idle like, between the two cams.
Author:  drmini in aust [ Fri Nov 11, 2005 9:45 pm ]
A bit more duration, bit more lift, bit more opening & closing acceleration.
731 is 268* duration and .252" lift (at cam),
RE13 has a little more duration but but a lot more lift (.290" at cam).
If you use `em with 1.5 rockers, to avoid coil bind you will need C-AEA526 valve springs (which have 1 less coil).
willy, the idle is about the same. :wink:
Author:  gafmo [ Sat Nov 12, 2005 11:03 pm ]
RE is slightley lumpier..
Author:  Stuwey [ Sun Nov 13, 2005 10:08 pm ]
I used to have a 731 in my hottie 998 van, willy.
When it was out of tune, it sounded like a bloody rotor. Brap, brap, brap.
But that was with a 12G295 head, and twin 1-1/4 SUs. That thing used to go alright for a 998.
Author:  Spaceboy [ Mon Nov 14, 2005 12:27 am ]
having been the only cammy motor i've driven, it gets going from about 2500-3000rpm
with the real power kicking in at 3000
still going nicely to 6000+
its an old works rally cam, so its been surpassed by more modern profiles.
the idle is a little bit lumpy, but not enough to piss me off..
i hate lumpyness and general lack of smoothness.
Author:  Stuwey [ Wed Dec 07, 2005 10:42 pm ]
So remind me why you drive a mini :?
I like my Scatter pattern cam because it doesn't lump like the rest. A little less attntion from the boys in blue :wink:
