my starter motor ???
https://www.ausmini.com/forums/viewtopic.php?f=5&t=13151
Author:  brett [ Mon Nov 14, 2005 9:05 pm ]
Post subject:  my starter motor ???
Hi my Cooper S starter motor playing up.
It will eventually turn over but sometimes the Cooper S will click, or do a continous clicking. The Car will give the flat battery trying to turn over but then eventually it starts.
The earth lead gets very hot, sounds like my Earth what does every one here think??
Author:  9YaTaH [ Mon Nov 14, 2005 9:35 pm ]
Post subject:  Mods
So what A Series or A+ Mods has it had done to it......
Author:  brett [ Mon Nov 14, 2005 10:21 pm ]
1310cc stage 3 Downton head
1.5" twin su
Works cam
Author:  9YaTaH [ Mon Nov 14, 2005 10:27 pm ]
Post subject:  OK
1.5" twin su
Works cam
Assuming it don't have a huge compression ratio then the stock starter motor should cope....check all your earths for good contact (thats nice shiney metal to shiney metal)....but it sounds like you have a shorted turn in your starter motor....may need to try check your solenoid or try another starter motor...soon :D
Author:  Circus_Maximus [ Tue Nov 15, 2005 11:53 am ]
Starter could be poleing (stalling), this draws such heavy current it could quite possibly buckle your battery plates and stuff the battery very quickly (both cables not just the earth would be getting warm). I have found on mine the reason was the bearings (Bronze bushes) were worn particularly the rear allowing the armature to move out of position and actually bind against the pole pieces.
My final solution was the Gemini one..... :)
Author:  danidad [ Tue Nov 15, 2005 5:51 pm ]
both of the above but dodgy earths are very common causes of problems even those undiagnosed things that just seem to happen periodicaly.. as cleaning contacts id free start there first ....... earth braids can become faulty too..
failling that prolly throw money at starter
Author:  brett [ Sat Jan 07, 2006 7:30 pm ]
I am going to order a new starter motor what sort do I need its a 1967 Cooper S genuine motor.
CHeers Breett
Author:  drmini in aust [ Sat Jan 07, 2006 8:03 pm ]
If you have the stock S' 13 row cooler there your options are limited to a Lucas, really. I bought a re-manufactured one (done in UK) from Karcraft, it's been great. 8)
Of course now I've flung the cooler off, I have other options in future- eg either the Gemini, or a pre-engaged one sold my Heritage MG in Sydney.. :wink:
Author:  jacks1071 [ Sat Jan 14, 2006 12:03 am ]
CHeers Breett
If you want something really good get a Brise - very expensive though $660 delivered from www.minisport.com.au - they work very well, crank like anything and don't run your battery flat.
Jacks.
