Japanese Clutches https://www.ausmini.com/forums/viewtopic.php?f=5&t=1326 |
Author: | 9YaTaH [ Wed Jul 28, 2004 9:19 pm ] |
Post subject: | Japanese Clutches |
I was reading an article by Paul Gulson where he pans the Borg and Beck and recommends a Japanese clutch with a "spoked" centre. Ring any bells? Wheredayagetem? |
Author: | min13k [ Wed Jul 28, 2004 9:25 pm ] |
probly a 4 puck clutch like whatthey run on the ricers makka |
Author: | gafmo [ Wed Jul 28, 2004 9:29 pm ] |
Over my Head and Will I get one with my 1275 A+ coming from japan ![]() |
Author: | drmini in aust [ Wed Jul 28, 2004 9:47 pm ] |
Only spoked centre ones I've seen/used were all Taiwanese crap, facings like Kellogg's packets, piss-weak diaphragms... ![]() I'll stick to B&B thanks... ![]() |
Author: | gafmo [ Wed Jul 28, 2004 10:04 pm ] |
B&B ![]() ![]() |
Author: | drmini in aust [ Wed Jul 28, 2004 10:07 pm ] |
Borg & Beck (original equip) made in UK... ![]() <edit> and they come with a decent RHP release bearing.. not a POS asian made one. Last one of these lasted 3 weeks, a personal record. ![]() |
Author: | gafmo [ Wed Jul 28, 2004 10:49 pm ] |
So what is the best one DR and what sould we look 4. I would normal say a light and Balance with the same backing plate |
Author: | Christoph [ Wed Jul 28, 2004 10:58 pm ] |
Mick, you arent talking about a verto clutch are you? they were fitted to jap minis. |
Author: | drmini in aust [ Thu Jul 29, 2004 8:01 am ] |
gafmo wrote: So what is the best one DR and what sould we look 4. I would normal say a light and Balance with the same backing plate
If you want to lighten and balance the flywheel & backplate, best time to balance it is with the new diaphragm. You don't really need your crank- Russell Eng and most others have a balanced crank sitting there they use to balance yours bits. Whatever you do, don't lighten a flywheel and not balance it. They are cast iron, which has variable density- it WILL be out of balance after lightening. With backplates, the best one to lighten is the original S one- marked 22G270. These are SG iron- all the others are grey cast iron and can go BANG at high revs if you overdo the lightening bit. I really don't like weakening these. See Vizard's HTMYM book... |
Author: | 9YaTaH [ Thu Jul 29, 2004 9:34 pm ] |
Post subject: | Who me??? |
Christoph wrote: Mick, you arent talking about a verto clutch are you? they were fitted to jap minis.
Hey Chris, I ain't sayin nuttin!! Its a quote from Paul Gulson - he may mean verto but ity could mean sumthin else???? OK Doc, what colour/spot do recommend as the all time best Mini Clutch?? |
Author: | gafmo [ Thu Jul 29, 2004 10:21 pm ] |
Excelent Question..Over 2 u Dr |
Author: | drmini in aust [ Thu Jul 29, 2004 10:43 pm ] |
Blue spot. Cooper S stock. Unless your engine's got real serious mumbo, and can slip a blue- then you go get the orange spot rally one.. My 1310 still gets by with a blue spot one, as do a few 1380s I know of.. ![]() Prefer Bork & Beck brand, or Unipart. I think Delphi (made in EEC) is OK too, so I've been told. Not asian made junk...! I buy mine from Karcraft. <edit> This is for ROAD use.... Racers might want a sintered paddle clutch plate or a bonded/rivetted rally plate. Overkill for the street, IMO. |
