hydraulic lifters https://www.ausmini.com/forums/viewtopic.php?f=5&t=13409 |
Author: | h0nk [ Wed Nov 23, 2005 7:21 pm ] |
Post subject: | hydraulic lifters |
Is it possible to get hydro lifters for a mini engine? Do you need to get a hyrdo camshaft aswell or can you stick to the solid state cam? |
Author: | drmini in aust [ Wed Nov 23, 2005 7:45 pm ] |
No way to run hydraulic lifters in a Mini, the oil gallery for pressure feed ain't there. Ummm WHY would you? ![]() |
Author: | Morris 1100 [ Wed Nov 23, 2005 8:05 pm ] |
drmini in aust wrote: Ummm WHY would you? So that you could run anti-pump up lifters of course. ![]() ![]() |
Author: | h0nk [ Thu Nov 24, 2005 6:49 am ] |
quieter, low maintenance, my engine isn't very high performance - looks like i'll be keeping the solids anyway |
Author: | drmini in aust [ Thu Nov 24, 2005 7:07 pm ] |
h0nk wrote: quieter, low maintenance, my engine isn't very high performance - looks like i'll be keeping the solids anyway
Your engine is antique, designed ~ 1952- probably before hyd lifters were invented. There was even a version of it in a (Mini) tractor. ![]() Solids give more power anyhow, usually..... ![]() |
Author: | h0nk [ Fri Nov 25, 2005 11:53 am ] |
I'll stick to the solids.. but with the oil gallery, can't you just use hollow push rods? |
