It is currently Mon Jul 21, 2025 5:23 am
 Post subject: 1310 on ebay
PostPosted: Mon Nov 28, 2005 8:28 pm
http://cars.search.ebay.com.au/mini_Car-Parts_W0QQcatrefZC12QQfromZR8QQfrtsZ300QQfsooZ1QQfsopZ1QQsacatZ72364
wat u rekon waste of money???
PostPosted: Mon Nov 28, 2005 8:30 pm
heres the link u want...
http://cgi.ebay.com.au/Mini-1310-Motor_ ... dZViewItem
PostPosted: Mon Nov 28, 2005 8:35 pm
Its a 3 cylinder version! :lol:
Not bad price, if everything is correct.
I guess it's only a head gasket - being a 1310 they arent the best for head gaskets.
PostPosted: Mon Nov 28, 2005 8:41 pm
Including G/B that's ok... So long as it is running on 3and not let a big end bolt go or dropped a valve or something like that...
PostPosted: Mon Nov 28, 2005 9:24 pm
possible burnt valve or done a ring if its only 20psi down on one cylinder. if it dropped a bolt, just spinning to do the compression test would probably make nasty sounds
not a bad price for a rebuilder
PostPosted: Tue Nov 29, 2005 5:46 am
If only 20psi down on one cyl it's probably just a valve. Fix that first and it could be OK.
I agree, price is good.... even better if it's a good runner. 8)
PostPosted: Tue Nov 29, 2005 12:37 pm
Even even better if that was a remote box under there :wink:
PostPosted: Tue Nov 29, 2005 3:46 pm
I emailed the guy - the motor is a 12H902UH and the gearbox is SM 2261832
PostPosted: Tue Nov 29, 2005 7:46 pm
would be 22G1832 = rod change box, small idler (ie std Oz one).
PostPosted: Wed Nov 30, 2005 8:51 am
Still worth it for a complete engine with all the gear (dissy, alternator etc)
Users browsing this forum: No registered users and 18 guests
