Valves & porting https://www.ausmini.com/forums/viewtopic.php?f=5&t=13631 |
Author: | scotty [ Thu Dec 01, 2005 7:42 pm ] |
Post subject: | Valves & porting |
Quick q time. Found a head relatively cheap (mines a stack shitta), the underneath has got oversized valves but has not been machined out (square instead of rounded out like a 12g295). Will this make any difference? All other port work has been done. |
Author: | drmini in aust [ Fri Dec 02, 2005 5:40 am ] |
It sounds like probably a 12G202 head off a 1098 (or the rarer 12G206). Check number cast on head under rocker gear. Either of these is better than a stocko 998 one. A 295 head is basically same as a 206, but machined to take manifold locating rings. |
