It is currently Mon Jul 21, 2025 8:36 am
 Post subject: Valves & porting
PostPosted: Thu Dec 01, 2005 7:42 pm
Quick q time. Found a head relatively cheap (mines a stack shitta), the underneath has got oversized valves but has not been machined out (square instead of rounded out like a 12g295). Will this make any difference? All other port work has been done.
PostPosted: Fri Dec 02, 2005 5:40 am
It sounds like probably a 12G202 head off a 1098 (or the rarer 12G206). Check number cast on head under rocker gear.
Either of these is better than a stocko 998 one.
A 295 head is basically same as a 206, but machined to take manifold locating rings.
