do morris 1100 discs fit 71 clubman https://www.ausmini.com/forums/viewtopic.php?f=5&t=13953 |
Author: | cool_clubman [ Mon Dec 12, 2005 8:17 pm ] |
Post subject: | do morris 1100 discs fit 71 clubman |
I found some morris 1100 disc brakes and don't know if they will fit my 71 clubman. this is my first ever mini and i dont know much about themjavascript:emoticon(':D') Very Happy |
Author: | drmini in aust [ Mon Dec 12, 2005 8:54 pm ] |
Short answer = NO. ![]() But somebody here was attempting this feat. |
Author: | willy [ Mon Dec 12, 2005 9:25 pm ] |
A bloke in adelaide has done it. He had the rotors turned down to whatever they were to fit under his wheels ( i think) used morris 1100 calipers. And drum brake uprights. Made up mounting plates - no dodgier than your Honda crap let me tell you! ![]() And there it was. Morrie 1100 brakes on a mini. ![]() |
Author: | drmini in aust [ Mon Dec 12, 2005 9:29 pm ] |
willy wrote: A bloke in adelaide has done it.
He had the rotors turned down to whatever they were to fit under his wheels ( i think) used morris 1100 calipers. And drum brake uprights. Made up mounting plates - no dodgier than your Honda crap let me tell you! ![]() And there it was. Morrie 1100 brakes on a mini. ![]() Pfffft... Hondas will outstop them easy- they are 9.1", and are ventilated too if you grab Accord ones! BTW the mounting plates are 8mm thick... plenty. Sorry I don't do them any more though.... ![]() |
Author: | willy [ Mon Dec 12, 2005 9:57 pm ] |
And why dont you ![]() |
Author: | K-Bar [ Mon Dec 12, 2005 10:10 pm ] |
- Cono from mini craft here in perth makes a kit that allows the brakes to fit.. - Probably not worth it tho. |
Author: | drmini in aust [ Tue Dec 13, 2005 5:54 am ] |
willy wrote: And why dont you
![]() Not engineered, and neither are M1100s on a Mini if you succeed in fitting them. |
Author: | TheMiniMan [ Thu Dec 15, 2005 9:36 am ] |
lots of problems surrounding the fittment of morris 1100 disc assys,,, the upright/swivel hubs won`t work for starters, the ball joints are way too far apart & will leave absolutely no room for suspension travel at all, so different swivel hubs are needed or lift the upper inner control arm mounting point & shorten the strut/Hi-lo assy & raise the tower bump stop part of the subframe. (MAJOR DRAMA) The disc & caliper are too big to fit under 10" wheels & would need turning down & as the good Doc said, there`s many other brake conversions out there that will work far better about the only good thing is that you can actually use the disc rotor with the moke/1275LS brakes (if you had to) in that they`re only a tad smaller in diameterthan the moke/1275LS rotor, so they work, but only just & you`ll need to chip away all the over hanging (unused) brake pad material from time to time just simply not worth the stuff around YUK!!!!!!!!!!!!!!!!!!!!!! |
