Fitting a Civic Dizzy https://www.ausmini.com/forums/viewtopic.php?f=5&t=14226 |
Author: | VanMan [ Thu Dec 22, 2005 1:32 pm ] |
Post subject: | Fitting a Civic Dizzy |
I read recently in an old copy of Mini Majic Magazine that it'is possible to fit a honda civic 80 model distributor. Has anyone fitted one? could they let me know how to wire up the igniter? Any help would be appreciated. ![]() |
Author: | drmini in aust [ Thu Dec 22, 2005 3:58 pm ] |
Yeah we used to do that mod, but these days it's way easier and HEAPS less work to go find a dizzy from a Nissan Pulsar N12. Look for numbers D4R83 or D4R85 on the dizzy body. These take less than 20 mins work to fit, the Civic is a lot more involved. Also the Pulsar one has the ignitor in the dizzy, much easier to hook up. Both the Civic and Pulsar are Hitachi dizzys and similar otherwise. See my thread `how to fit a Pulsar dizzy to yer Mini' in the how-to forum. ![]() <edit> If you have a well modified motor with big cam, high compression, worked head etc the D4R85 works well. But if you can find a Nissan Sentra (import) its D4R82 would be even better- it has 10* advance weights, not 12* like the 85 does.. ![]() |
Author: | VanMan [ Fri Dec 23, 2005 10:02 pm ] |
Thanks fo rthe heads up. I'll hit the wreckers and see how i go. |
Author: | ausminis4u [ Sat Dec 24, 2005 8:33 pm ] |
hi the honda setup works great ( and looks better imo.) i have done 3 or 4 of these setups and i am running on in my paddock bashed at the moment . if you do end up going honda i can help u with it . |
Author: | mattywood [ Tue Jan 17, 2006 8:04 pm ] |
Hi guys, can you tell me what the benefit is of using the pulsar dizzy? |
Author: | Tinkz [ Tue Jan 17, 2006 8:12 pm ] |
As far as I know the drive gear on the pulsar dizzy is the same as the mini? I owned an N12 and converted it to electronic dizzy. It uses the same coil as the points sytem and is very basic to set up. Too bad i didn't realise this before it went to the wreckers. |
Author: | drmini in aust [ Tue Jan 17, 2006 9:49 pm ] |
mattywood wrote: Hi guys, can you tell me what the benefit is of using the pulsar dizzy?
See the thread in how-to section- Basically- less spark scatter, so more power no points so stay in tune longer, don't cark it in wet weather, fatter spark- easier starting, better economy. They are far better made than the Lucas ever were. ![]() |
Author: | JAM_IT [ Wed Jan 18, 2006 7:13 pm ] |
drmini in aust wrote: fatter spark- easier starting,
you got that right! On a cold start mine is never more then 2 cranks to fire up ![]() |
Author: | mattywood [ Wed Jan 18, 2006 8:26 pm ] |
cheers for the help |
