1275 auto block- convert to manual (with pics) https://www.ausmini.com/forums/viewtopic.php?f=5&t=1461 |
Page 1 of 3 |
Author: | drmini in aust [ Sun Aug 08, 2004 8:59 pm ] |
Post subject: | 1275 auto block- convert to manual (with pics) |
OK I'm about to convert my recently acquired 1275 auto block into a manual one. Done one before- so anybody in Sydney using one for a doorstop and wants it converted, drop me a line. ![]() Mods involve making & fitting an alloy spacer for the oil pump, drilling 2 oilways, modifying the relief valve seat and drilling a dipstick hole. ![]() |
Author: | supercharged 850 [ Mon Aug 09, 2004 4:14 am ] |
i was thinking of converting my manual 1275 into an auto.... So, i'll need the bits you'll be drilling out to plug up my oilways and dipstick hole..... ![]() Sorry, bad joke.... i need a coffee... |
Author: | drmini in aust [ Mon Aug 09, 2004 7:28 am ] |
One day, just for fun, I'd like to build a 1425 auto with a hi-stall converter.. ![]() ![]() |
Author: | ausminis4u [ Mon Aug 09, 2004 9:06 am ] |
Post subject: | Re: 1275 auto blocks to manual |
drmini in aust wrote: OK I'm about to convert my recently acquired 1275 auto block into a manual one. Done one before- so anybody in Sydney using one for a doorstop and wants it converted, drop me a line. mate where can i get a 1275 auto from ?
Author: | bnicho [ Mon Aug 09, 2004 1:05 pm ] |
I'd love to know where you can get a high stall converter for a 1275 Auto! I don't think such a part would exist. If it does, I want one for the Matic-Moke! A 1425cc engine would probably kill an Auto. They are not renowned for their toughness. I'm building an Auto Moke just decided I wanted to play with something different. In the lightweight Moke the stock 1275 A+ Auto should go okay. ![]() |
Author: | drmini in aust [ Mon Aug 09, 2004 7:44 pm ] |
Auto box is tougher than you think. People have raced with them- but they do pull a few more HP out on the way thru to the wheels, according to Graham Russell. I've had two 1275 autos in Morris 1100S's, couldn't kill 'em... Just change the oil & filter regularly- like every 1500 miles... ![]() re the hi-stall converter- just about any torque converter rebuilder could mod a stock one. There's one in Seven Hills, right next door to where I'm working... ![]() A bloke in UK modified one to a race box. I'll post the article up here tonite when I find it. Here 'tis... ![]() ![]() |
Author: | bnicho [ Mon Aug 09, 2004 9:54 pm ] |
Hmmm, very interesting!!! Never though of using a clutch instead of a torque converter. In the Vic Mini Club a few of us are playing with Autos. One of my mates has been using his S-Matic in Motorkhanas for years, with sucess. Drivbing hs car planted my desire for an Auto Moke. Another mate has built a "twini" dune buggy using Mini front subframes front and rear. At the moment it has my A+ Metro Auto in the front and a A Morris 1300 Auto in the rear! If running one engine only, we both agree my A+ is quicker. But running them both at once sure is fun! ![]() |
Author: | supercharged 850 [ Tue Aug 10, 2004 1:39 am ] |
Hmmm... my roadster has an unleaded 1100 Auto - with an 1800rpm stall converter in it... i thought it seemed a little high, but who knows... |
Author: | drmini in aust [ Tue Aug 10, 2004 6:52 am ] |
Pretty sure all autos have the same converter. Bigger motors do make the stall speed higher, 1800 sounds about right for a 1275. I'd like it around 2600-2700, please... right where my cam hits paydirt! ![]() |
Author: | drmini in aust [ Thu Aug 19, 2004 6:53 am ] |
Auto 1275 block will be modified to have manual plumbing this weekend. I'll post some pics next week showing what's involved doing it. ![]() Seriously, this is not a dodgy mod. Once done (properly) the block is as reliable as a normal manual one. |
Author: | drmini in aust [ Sat Aug 21, 2004 4:28 pm ] |
To fit a 1275 auto block to a manual, apart from drilling the dipstick hole, there are a few mods needed to oil plumbing: 1. Auto block doesn't have the drilling all the way from the oil pump to the relief valve. 2. Auto block has 2 holes in the relief valve seat `cotton reel' to let oil get into the main gallery, because the normal filter flange is blocked off with a plate- the motor's lube oil comes UP the banjo pipe from the auto trans to the motor. 3. Auto block pump mounting recess is .250" deeper than in a normal 1275 block. The cotton reel needs to be pulled out & the 2 holes brazed or welded, (or fit a manual one) then a 1/4" spacer plate made and bolted in, then the oil pump's 3/8" dia outlet hole drilled in the block 1/4" deep. Finally the relief valve's oil feed drilling can be extended to the pump outlet hole with a long series 8.5mm drill. Note this hole was offset in manufacture to miss the #4 cylinder bore- it can't be drilled properly with the cotton reel still in the block. The hole is already in there, but is about 20mm short.... ![]() Spacer must be bolted in there as the drilling will come thru the joint between spacer and block. Here's a few pics: Standard auto block's relief valve seat: http://www.flickr.com/photos/31275265@N05/9070535679/ Modified relief valve seat (the 2 holes brazed up) and new alloy spacer plate: Drilling the pump outlet hole: Block and spacer plate after drilling oil feed hole from relief valve- Still needs a little cleaning up with the die grinder... Finished spacer mounted (temporarily) in block- Now that the 7/16" dipstick hole is drilled, the block can be bored and hot tanked. Gotta decide wot pistons now.... decisions, decisions! ![]() ![]() Note: the spacer is a real neat fit & will be sealed with a gasket and Permatex #3 aviation gasket cement. Once sealed it will stay in there. If I ever want to remove it though, there's 2 tapped holes in it for jacking screws. <edit> The alloy spacer won't be fitted until after block is bored and hot tanked. ![]() <edit 2, 7/7/05 > originally I tried to seal between the pump spacer and block with Loctite 515 Master Gasket, and no gasket- but the pump sucked air. It's fine now with a gasket fitted. ![]() |
Author: | drmini in aust [ Tue Aug 31, 2004 8:17 pm ] |
1360cc Hypatec pistons (73.0mm) ordered. Good things come from Qld... ![]() Now do I keep a stock 1100S crank or stroke this sucker, tooooo... ![]() If I get crank stroked to 84.0mm, it'll be 1405cc.. ![]() |
Author: | Lillee [ Tue Aug 31, 2004 8:30 pm ] |
Gee I wish you were making this engine for me ![]() Abopt me Kev! ![]() I wish i had the time to come around and see all this happenning ![]() |
Author: | drmini in aust [ Thu Jul 07, 2005 7:12 pm ] |
This 1300 auto block is in my car now, 1360cc, S crank and running hard. ![]() Only thing I have now added to this story- don't try and get away without using a gasket behind the oil pump spacer plate. Pump will suck air & not prime without a good seal here. ![]() |
Author: | Mowog [ Thu Jul 07, 2005 10:56 pm ] |
Post subject: | Mini autobox |
Hi all. I'm putting together an auto 1275 for my wife, who can't drive a manual. Obviously I want to be able to keep her on the road for as long as possible. Anyone (in Adelaide especially) looking to offload any auto parts please get in touch. |
Page 1 of 3 | All times are UTC + 10 hours |
