honda civic discs https://www.ausmini.com/forums/viewtopic.php?f=5&t=163 |
Page 1 of 31 |
Author: | ausminis4u [ Sun Mar 28, 2004 7:46 pm ] |
Post subject: | honda civic discs |
help please! i got a set of discs/calipers today from the tip off a wreck. i dont know if they are correct , any distinguishing fearures? how many holes did the honda rotors have on the flange face? coz mine have 8 holes. i dont no what model it was except that it was an automatic civic from the 80s coz it had the elec dizzy aswel ![]() |
Author: | drmini in aust [ Sun Mar 28, 2004 9:52 pm ] |
Should have 4x 12mm boltholes on 100mm PCD, width overall 44mm, diameter 229, were 12mm thick when new. Regrind limit is 10mm, DBA disc #191 I think, what are they worth new...??? <edit> also check out RDA discs, they are cheaper but good. I've got a set of 7.5s on my Mini.. EBC Greenstuff pads are 3/4 worn but the discs still look sweet. ![]() |
Author: | leyland74 [ Mon Mar 29, 2004 6:07 pm ] |
With the Honda disk conversion, what about the drive shafts. If I'm going from original drums what bits do I need from the Civic/City and what other bits do I need. You need 10"x5 Contessas's is that right. They are ROH's right. I have bought a set of mags, I wasn't sure what they where but they had 2 Leyland S centers. After they where cleaned and resprayed I noticed on the inside they had ROH on the inside and look just like the ones for sale here: http://tziworld.com/ausmini/viewtopic.php?t=67 I'd like disks and to do the cheap Honda conversion. Is it possible. |
Author: | -=MiniMafia=- [ Tue Mar 30, 2004 9:12 am ] |
Got a few questions... What year do they have to come off? Cause me and gordie picked up 2 Honda civics from the local garage. now i think one is a 80's model, and one might be late 70's... (ill find out asap) will these work for the conversion? and what wheels will fit on them? i have some wide reversed rims, will they fit? and do you have to do anything to the rear drums? Cheers, and sorry ausmini4u, im not trying to steal your thread!!! |
Author: | drmini in aust [ Tue Mar 30, 2004 11:31 am ] |
Contessas fit, but NOT the `Mini S offset' ones. Use the wider track `Mini offset' ones. Re the Civic discs- if they are 44mm overall width they should be OK. You keep ALL the drum brake stuff except the drum brakes. Existing CVs, driveshafts, swivel hubs you use. Even the Mini brake hoses (but fit 2 copper washers). The Hondas will NOT fit on disc brake swivel hubs, unless you make different caliper mountings (maybe). See the 2 threads on www.miniportal.ca for info. Sorry the CD is not a goer, yet... ![]() <edit> steel wheels reversed or not, will NOT fit. You should fit S or Clubman S type rear drums if you don't have already. |
Author: | -=MiniMafia=- [ Tue Mar 30, 2004 11:52 am ] |
ahh ok, thanks for all that... its a shame how my rims wont fit hey! ![]() |
Author: | leyland74 [ Tue Mar 30, 2004 12:17 pm ] |
Thanks for the links again drmini, so how can I tell if I've got the Mini S offset ones or not (got a bad feeling I do since it came with Leyland centers) is there a way I can check. So I only need the disks and calipers then, when doing the Cooper S disk conversion is that only the disks and calipers too if so it f*&king expensive, I thought it included driveshafts and CV's so that's why it was around $1500. Sorry for the thread steal ausminis4u, I hope you've got all the info you need. ![]() |
Author: | drmini in aust [ Tue Mar 30, 2004 12:42 pm ] |
leyland74, the Contessas that DO fit have the spoke `bumps' about 20mm in from the extreme outer edge of the rim. They need flares to be legal, if using S or Honda disc brakes and S rear drums. These are `Mini offset' type. The other type have the spoke bumps flush (more or less) and will NOT fit. Track is narrower, they are just legal without flares. These are Mini S (known as `S') offset type. If you have these they are worth more $$ than the type above (why???) so if U want Honda discs, sell 'em and get some of the other type.. ![]() |
Author: | leyland74 [ Tue Mar 30, 2004 12:55 pm ] |
Thanks, I'll check them when I get home. I'm pretty sure they are not flush so that's good news. |
Author: | leyland74 [ Tue Mar 30, 2004 7:00 pm ] |
The bumps seem to be more or less flush so that means they're the mini S type "Doh" and I just had them sand blasted and resprayed in 2pac silver then clear (look smick). Hmm have to think about if I really want disks, especially when I'm going OS in 6 months. But God I love modifying/fixing cars it's an addiction. About how much are perfect condition mini S wheels worth? and how much for the other one's? |
Author: | drmini in aust [ Tue Mar 30, 2004 7:26 pm ] |
Depends on condition, but the ones like yours are rarer, and people with MK1 Cooper S's want them as they fit OK without flares.. Re the other type, again it depends how good they are. I've bought several OK S/H sets of 4 for $200, wheels only. ![]() |
Author: | Meck [ Wed Mar 31, 2004 4:24 pm ] |
Kev, do you know if Jellybeans fit? Cheers Matt |
Author: | drmini in aust [ Wed Mar 31, 2004 4:58 pm ] |
Yes. Uses 25mm spacer like the Contessas. There will be a Mini Deluxe in Castle Hill very shortly, with Jellybeans and Honda discs. ![]() I think any 4.5x10 or 5x10 MAG (not steel) with Mini (not S) offset will fit. ![]() |
Author: | Gordie [ Thu Apr 01, 2004 9:16 am ] |
why dont steal rims fit? not enough off set? or diameter not big enough? |
Author: | drmini in aust [ Thu Apr 01, 2004 1:03 pm ] |
Diameter inside rim is big enough, but the well is too close to the inner edge of the rim. S wheels would need 40mm spacers to fit- ie they will stick out an extra 15mm per side more than they would with S brakes. Bit illegal, and doesn't help the steering either. ![]() |
Page 1 of 31 | All times are UTC + 10 hours |
