Pulsar dizzy conversion question
https://www.ausmini.com/forums/viewtopic.php?f=5&t=17104
Page 1 of 2
Author:  KennyKix [ Mon Mar 13, 2006 6:54 am ]
Post subject:  Pulsar dizzy conversion question
Hey all,
I'm trying to convert a dizzy but i'm unable to remove the drive dog from the lucas dizzy.
I've tried using a 3/16" pin punch and also a 4.0mm pin punch and are unable to get the damn pin out. :evil:
I've soked the drive dog in Wurth Rust off plus (its like WD40 but it doesnt lubricate, just penetrates and its supposed to free things up a bit when they are rusty or just plain stuck) still cant get the drive dog off.
Any ideas?
Author:  Gerard [ Mon Mar 13, 2006 7:54 am ]
kenny can you hold the drive dog (ver gently) in a metal vice and belt the centre spigot back down through it with a FBH???
Geraerd
Author:  drmini in aust [ Mon Mar 13, 2006 8:02 am ]
Often, the edge of the Lucas drive dog has been staked in to retain the pin.
Hit it with a grinder to remove this both sides, pin will then punch out. Pin is a tight fit anyway, doesn't need to be staked in.
Author:  KennyKix [ Mon Mar 13, 2006 8:42 am ]
the pin is about 2mm in on each side, i would have to grind the side of the drive dog off to get to the pin, any other ideas?
Author:  drmini in aust [ Mon Mar 13, 2006 8:45 am ]
Just grind that part flat each side, it's no problem. I've done it heaps of times.:)
Author:  KennyKix [ Mon Mar 13, 2006 9:11 am ]
what about using a drill bit (used for removing spot welds) and drilling the ends off the pin?
where could i get a new pin?
Author:  h0nk [ Mon Mar 13, 2006 9:55 am ]
I'd do what doc says and grind down each side a bit.. I lost my pin when doing the conversion, just borrowd one of my dad's old 3/16" drill bits and cut that to size :D I don't think he's noticed yet..
Author:  smac [ Mon Mar 13, 2006 10:43 am ]
I have a complete set of drift punches...they came in a box labelled "allen keys" for some reason....
Author:  drmini in aust [ Mon Mar 13, 2006 11:24 am ]
The pins are hardened dowels I think, good luck trying to drill one.. :lol:
They are not just a roll (spring) pin like a Clubby gearbox shift rod has.
Author:  KennyKix [ Tue Mar 14, 2006 6:12 pm ]
So....I got the pin out :D
BUT....the pin punch is now offically stuck! :x
I've tried driving it back out with another pin punch.
I've tried holding the pin punch in the vice and pulling the dizzy off the punch.
Nothing is working! HELP!
Author:  drmini in aust [ Tue Mar 14, 2006 6:50 pm ]
Sit it on top of vice with the punch sticking up. Then use the next size punch down to drive the old one out. :wink:
I hope you used a 3/16" punch, and not forced a 5.0mm one in there... :lol:
Author:  smac [ Wed Mar 15, 2006 5:06 am ]
Punch sticking down?
Author:  drmini in aust [ Wed Mar 15, 2006 5:42 am ]
I mean body of jammed punch sticking down, its biz end pointing up. Smack the sucker down and out.. :wink:
Author:  KennyKix [ Wed Mar 15, 2006 5:51 am ]
I used a 3/16" and i've tried putting the punch in a vice and punching it back out but
it wont budge.
Author:  smac [ Wed Mar 15, 2006 5:56 am ]
hit it harder
