Power Tuning the 1275
https://www.ausmini.com/forums/viewtopic.php?f=5&t=18604
Page 1 of 3
Author:  cush [ Fri Apr 28, 2006 1:59 pm ]
Post subject:  Power Tuning the 1275
This can include the 970 and 1070 big bore boys if you like.
Author:  Lillee [ Fri Apr 28, 2006 2:07 pm ]
Cush, it's the same for all engines, not just mini engines.
More air + more fuel = more power
Make it breath better in and out, provide adequate fuel to match that air flow, make internal components lighter so it spins easier.
For A series it's even more all the same. Head work, bigger carb, better intake, better exhaust.
ANSWER: READ YOUR VIZARD BOOK! 8)
Author:  cush [ Fri Apr 28, 2006 2:34 pm ]
ruiner... :)
Author:  Lillee [ Fri Apr 28, 2006 5:02 pm ]
Who me? No 8)
Author:  h0nk [ Fri Apr 28, 2006 7:54 pm ]
Excellent info, very useful. This should be a sticky.
Author:  gafmo [ Fri Apr 28, 2006 8:42 pm ]
But thier are others that have some secret's that they will not devolge :wink:
Author:  Spaceboy [ Sat Apr 29, 2006 1:58 am ]
i believe the best way to modify a BIG BLOCK 1275 would be to STROKE IT and keep the revs down with a MEATY cam and balance the hell out of it, as 1275's are ROUGH
keep the heavy flywheel to lay big blackies
Author:  drmini in aust [ Sat Apr 29, 2006 8:21 am ]
Speak for yourself, my 1360 with S crank & rods is dead smooth from 3K-8K... :lol:
Only the big journal 1100S ones with those bloody heavy rods are rough, IMO. :wink:
Author:  Lillee [ Sat Apr 29, 2006 11:48 am ]
Best way is to make everything as light as possible so that it spins freely from standstill to 7000+ rpm. Make sure it breaths effortlessly and deeply, increase the compression ratio and way you go :wink:
Author:  drmini in aust [ Sat Apr 29, 2006 12:08 pm ]
No need to lighten much on a small journal roady motor- I just used the stock Cooper S crank and rods, all balanced though. :wink:
Author:  1360 LS [ Tue May 02, 2006 8:16 am ]
I've a 1360 with S rods crank etc... mine only revs to 5- 5.5 ... mind you no headwork or cam work . should my car be able to be revved higherr or its that the best . Dont wnat a race car as its a daily.
Author:  Lillee [ Tue May 02, 2006 8:44 am ]
Hello 1360 LS, do you have a green LS? I see a green LS in the mornings sometimes driving through Five dock...
If you have a stock head and cam there may be no more power above 6000 anyway
Author:  Spaceboy [ Tue May 02, 2006 8:47 am ]
the tacho redlines at 5.5k so thats normal.
with modifications, they will see crazy revs, but yeah totally unneccesary for a daily driver.
the stock cam is probably the best for traffic use as i find most fast road cams only start delivering power around 3000 rpm, and thats when you should be changing gear.
Author:  Mini Mad [ Tue May 02, 2006 3:16 pm ]
3000rpm? Who says? :lol:
Author:  1360 LS [ Wed May 03, 2006 7:12 am ]
there's a green one around my area???? can't say i seen it. I have a Hi ho Silver LS number plate KAE 883 . I told there original plates too. keep a eye for me in the next couple of weeks coz thats all I have my licence for. Losing it as soon as I get a RTA notice.
only green Mini I seen around my area is a solid panel van.
Page 1 of 3 All times are UTC + 10 hours
