It is currently Tue Jul 22, 2025 3:43 pm
PostPosted: Fri Jun 09, 2006 11:28 pm
then what does one do to the distributor when they fit a weber to an engine previously running an SU?
Do i just pull the vaccuum hose off the distributor and leave it be? Do i need to do any mods to make it work without it?
Also, i have a vaccuum gauge on my dash, can i just run the vaccuum hose to the inlet manifold for the signal?
PS: I have a D4R83 Pulsar distributor. ;)
- Simon -
PostPosted: Sat Jun 10, 2006 12:00 am
Just leave it disconnected..
PostPosted: Sat Jun 10, 2006 12:20 am
it was suggested that i may need a different distributor or the one i have regraphed or something.
- Simon -
PostPosted: Sat Jun 10, 2006 8:20 am
The vac advance in most dizzys is just an economy device. SUs use `em, Webers & Dellortos don't and there's no way really to connect them to use it due to the fluctuating vacuum at the throttle plates.
At full throttle they do nothing anyway. :lol:
I just leave it off... works fine for me. 8)
Cooper S never had it, nor did twincam Fiats, Alfas etc.
If using a Pulsar dizzy without vac, the D4R85 is the one to grab. It will give you more static and low speed advance than the 83 does. :wink:
