It is currently Tue Jul 22, 2025 3:40 pm
PostPosted: Tue Jun 06, 2006 8:03 am
Just a query regarding these later type of alternators. Those selling them say check with an auto electrician before installation? :? :?
Just curious if there are major differences to the wiring up or is more a precaution that your aging lucas wiring loom may not be able to take the load??
TT :)
PostPosted: Fri Jun 09, 2006 9:25 pm
TT :)
Just ensure there are 2 heavy wires from the 12V+ terminal back to the battery lead stud on the solenoid. Early cars with 15AC alternators only had 1.... not enough for a 65A+ alternator.
Rest of the car's wiring will be OK, no problem.
PostPosted: Fri Jun 09, 2006 10:53 pm
Summ's it up..White Wires
PostPosted: Sun Jun 18, 2006 4:23 pm
Yeah the only difference is the two wires. I've got a 16ARC on at the moment but isn't good enough, I've started to modify an N16 Pulsar Alternator, so far it looks good that it will fit. What sort of output is the 17ACR, my 16ARC is about 30-40 amps but the pulsar one is about 70-75amps, so whats the 17ACR rated at?
PostPosted: Sun Jun 18, 2006 5:11 pm
36A, according to Google. :wink:
PostPosted: Sun Jun 18, 2006 10:00 pm
36 amps ay? I think I'll keep modifying my Nissan one, just a few cms of steal to cut off and presto!
PostPosted: Mon Jun 19, 2006 12:23 pm
55Amp according to the Haynes manual iirc
