best bearings for disc brakes https://www.ausmini.com/forums/viewtopic.php?f=5&t=20024 |
Author: | cbs [ Fri Jun 09, 2006 9:27 pm ] |
Post subject: | best bearings for disc brakes |
Hi folks, just pulled apart my newly bought disc brakes, have got timken bearings in them. They look ok but I am going to replace them anyway to be sure. Is there a better brand to go for or are they an ok brand? Thanks in advance!!! |
Author: | drmini in aust [ Fri Jun 09, 2006 9:30 pm ] |
Timkens ARE the best. They invented the tapered roller bearing... ![]() There are other brands (some no-name) around now, they are cheaper but I doubt as well made. If you replace them, buy them as a kit. The spacer between them is hand selected to match the 2 bearings in the kit. Buy loose industrial bearings, and you will have to mess with spacer thicknesses probably. Not good unless you know what you are doing... |
Author: | cbs [ Fri Jun 09, 2006 9:33 pm ] |
Thanks DRMINI, had a feeling they were ok, just wanted to make sure before I got some tomorrow ![]() |
Author: | cush [ Fri Jun 09, 2006 10:04 pm ] |
drmini in aust wrote: Timkens ARE the best. They invented the tapered roller bearing...
![]() There are other brands (some no-name) around now, they are cheaper but I doubt as well made. If you replace them, buy them as a kit. The spacer between them is hand selected to match the 2 bearings in the kit. Buy loose industrial bearings, and you will have to mess with spacer thicknesses probably. Not good unless you know what you are doing... listen to the doc.... buy cheap japanese bearings... ![]() especially in the clutch... ![]() |
Author: | drmini in aust [ Fri Jun 09, 2006 10:23 pm ] |
cush wrote: listen to the doc.... buy cheap japanese bearings...
![]() especially in the clutch... ![]() NOT... ![]() That's another story, we won't go there... ![]() Hey I thought some Jap bearings were crap, but Chinese ones are infinitely worse... their ball bearings usually have end float when new!!! ![]() |
Author: | cush [ Fri Jun 09, 2006 10:33 pm ] |
i think i meant chinese.... which ever ones you always go on about lasting for 5 minutes... ![]() |
Author: | HPDesign [ Fri Jun 09, 2006 11:40 pm ] |
cush wrote: i think i meant chinese.... which ever ones you always go on about lasting for 5 minutes...
![]() did I hear that right CUSH Thought........ ![]() ![]() |
Author: | Mini Mad [ Sat Jun 10, 2006 12:57 am ] |
he's thinking now about a response...wait for it.. |
Author: | HPDesign [ Sat Jun 10, 2006 3:41 pm ] |
Author: | cush [ Sat Jun 10, 2006 6:18 pm ] |
is that fettucini i can smell? nope.. it's sulphur.... ![]() |
Author: | HPDesign [ Sun Jun 11, 2006 10:24 pm ] |
what kinda comeback was that.... surley we were meant to be talking about wheel bearings. Another Cush can't read the title moment perhaps? |
