So if i can't run vaccuum advance... https://www.ausmini.com/forums/viewtopic.php?f=5&t=20029 |
Author: | Molina [ Fri Jun 09, 2006 11:28 pm ] |
Post subject: | So if i can't run vaccuum advance... |
then what does one do to the distributor when they fit a weber to an engine previously running an SU? Do i just pull the vaccuum hose off the distributor and leave it be? Do i need to do any mods to make it work without it? Also, i have a vaccuum gauge on my dash, can i just run the vaccuum hose to the inlet manifold for the signal? PS: I have a D4R83 Pulsar distributor. ![]() |
Author: | h0nk [ Sat Jun 10, 2006 12:00 am ] |
Just leave it disconnected.. |
Author: | Molina [ Sat Jun 10, 2006 12:20 am ] |
it was suggested that i may need a different distributor or the one i have regraphed or something. |
Author: | drmini in aust [ Sat Jun 10, 2006 8:20 am ] |
The vac advance in most dizzys is just an economy device. SUs use `em, Webers & Dellortos don't and there's no way really to connect them to use it due to the fluctuating vacuum at the throttle plates. At full throttle they do nothing anyway. ![]() I just leave it off... works fine for me. ![]() Cooper S never had it, nor did twincam Fiats, Alfas etc. If using a Pulsar dizzy without vac, the D4R85 is the one to grab. It will give you more static and low speed advance than the 83 does. ![]() |
