It is currently Tue Jul 22, 2025 4:16 pm
 Post subject: parts
PostPosted: Tue Jun 27, 2006 11:20 pm
where are some good places to be buying parts to rebuild a clubman engine
i have a 998 engine which i have bought a 1100 crank to put in it and also a turbo to go on there as well
so i am after some good parts so the engine wont fall to bits
also when converting ur drum front brakes to disk brake using the mini disk brake setup do you have to get it enginereed
thanks for that guys
PostPosted: Wed Jun 28, 2006 6:49 am
For Hypatec pistons (good) try Mini Sport in SA-
http://stores.ebay.com.au/Minisport1275
No, if fitting a Mini or Metro disc brake setup, engineering is not required.
PostPosted: Wed Jun 28, 2006 1:11 pm
Hi Capt. Sparrow,
Where in Geelong are you?? I'm in Clifton Springs.
Good place for bits and pieces both old and new, is Bellarine Mini Centre, Cedar parade, Moolap. The guy there is Peter and you can reach him on 5248 8741.
Look forward to catching up with you.
Rod Image
PostPosted: Wed Jun 28, 2006 6:13 pm
im from grovedale
i have been out there before but didnt buy anything off him wat are his prices for engine parts
