Alternator conversion - Lower adjustment arm source UPDATED https://www.ausmini.com/forums/viewtopic.php?f=5&t=20745 |
Author: | pristic [ Sun Jul 02, 2006 10:02 pm ] |
Post subject: | Alternator conversion - Lower adjustment arm source UPDATED |
Hi Everyone, I recently had my alternator stop alternating ![]() See the pic here: ![]() Well, I found 2 brackets which suit so well they needed no mods or welding. 1973 Falcons (the alternator is on the top left of the motor (inline 6) and there is a VERY long adjustment bracket on top. 1985 Magna (the alternator is on the bottom right of the engine and has an AWESOME curved bracket that also has a belt adjustment bolt - oh, so easy. UPDATE Ford Cotrina 4.1l (inline 6) has the same bracket as the falcon too. Looong and cuurvey ![]() I grabbed one of each and ended up using the Magna one. Fits like a glove! I also decided to use one bolt in the top, but the bolt that came with the alternator was bigger in diameter than the holes in the bracket and water pump. I grabbed an 8mm threaded rod and used that... oh, too easy. I'll post a pic of the finished job asap. Cheers, Peter [/img] |
