It is currently Tue Jul 22, 2025 4:10 pm
PostPosted: Sun Jul 09, 2006 6:55 pm
Anybody know if the late Moke wipe/wash and indicator/dip switch will fit a Mini K steering column with no modifications to the column?
I am sick of not being able to reach the wiper switch in Melbourne drizzle when it has to be on/off, on/off all the time.
Mini K, 1310, Jet Red/Crystal White Roof, Rover Interior
75 Clubman
PostPosted: Sun Jul 09, 2006 7:38 pm
No. The reset button thingy that comes out of the column is in a different spot. You are better off putting in the whole column, switches, steering lock & shroud assembly. If you want all the fruit, buy a complete Rover column from Steve @ Brickworx. Non-airbag one will have same steering wheel mount splines as your K.
M
PostPosted: Sun Jul 09, 2006 8:57 pm
Could I not use a Moke steering column
75 Clubman
PostPosted: Sun Jul 09, 2006 10:42 pm
Yep, just check where the piece on the outside of the column is that keys into the dash bracket & stops the whole lot from turning. It may be in the wrong spot, but I doubt it. Should be fine.
