Now you see,,, this is where i chime back in & say---> ""Why do rolling roads sark?""
After all, it all basically comes back to the entire package,,, if one car has this & the other has that & one car runs turbo & the other doesn`t & one has zippy gearing & the othr doesn`t & one has big rubber & the other doesn`t & & & & &
welll this is the perfect way to compare the entire packages,,,, this is what i`ve been trying to get across for ages & ages
it`s all good & well getting a massive Hp figure on an engine dyno,,, it`s all good & well finding a wonderful package that produces "What looks to be" a dam good torque curve on an engine dyno,,, but when the chips are down, it`s all how it makes it to the road that counts
someone can have a wonderful engine package, but if it`s all farked up through a poor gearbox & final drive & wheel tyre & suspension set up, then all those wonderful "engine dyno" figures account for diddly squat on the road
for instance---> a decent race engine will need a super close ratio box to get it to work more effectively on the track,,, but an engine dyno won`t know that,,, it won`t "See" that,,, it has no clue about gear ratios & how it effects the performance on the track,,, it`s simply not relative at all
but in the real worl that same engine "Without" the close ratiobox would be left behind by a decent road engine with braorder spread & wide ratio box
same goes with a trubo car,,, it may just simply spin wheels & not get anywhere """IF""" the rest of the package isn`t suited
There is a place for rolling road dynos & they can be used to compare "Complete Packages" in a more "Real life terms" situation,,, & i`m not saying they are perfect,,, (obviously they`re not) but if you work with one of them, & use that same one for the comparisons,,, then what`s the difference & who cares about "Peak" hp
i`m more for making the whole package work on the black stuff in a real life situation,,, that`s where the differences really show from one "Car" to another
_________________ No offence intended here but--> anyone writing a book about minis 30 years ago may not have experienced such worn or stuffed-with components as we are finding these days.
