It is currently Fri Jul 18, 2025 1:44 pm
 Post subject: spot welds
PostPosted: Thu Oct 07, 2004 11:49 am
what size and kind a drill bit is best to use when drilling out spot welds?
and does anyone have the dimensions for some brace bars for when fitting a flip front?
cheers :lol:
PostPosted: Thu Oct 07, 2004 11:53 am
I think I used a 1/4 inch bit for drilling out spot welds.
PostPosted: Thu Oct 07, 2004 12:37 pm
Gordie there was a post on here a little while ago where somebody gave a link to like "howtofitaflipfronttoyourmini.com".
This may be it. Can't remember
http://www.manchester-minis.cwc.net/technical/flip_front1.htm
 Post subject: Re: spot welds
PostPosted: Thu Oct 07, 2004 1:15 pm
In the UK you can buy a special spot weld drill bit at every Halfords (like Autobarn). It has a different shape tip for a very shallow cut.
So far I have not turned one up in Oz (tried Repco, Auto-Pro, Auto-One etc). So I use a 1/4" bit as well.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Thu Oct 07, 2004 4:02 pm
Bnicho - You can buy the same drill bit here as well.
I bought mine from a panelbeater's supply shop. I'd ask at a repco store as well. If they don't have it they may be able to order it in for you. It is specifically designed to drill out spot welds.
PostPosted: Thu Oct 07, 2004 5:56 pm
Guy at Repco didn't know what I was talking about. I'll go back and try again!
Cheers for the tip. 8)
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Thu Oct 07, 2004 6:05 pm
KC tools will be able to help you
main page
catalogue page
PostPosted: Thu Oct 07, 2004 8:43 pm
The most successful way I have used is an 1/8" drill, find the centre of the spot weld and drill straight thru. Look for a hardened panel steel drill bit, they last longer. This way was quicker overall, and you don't end up with such a big hole. Takes a little to separate the panels, a screw driver does it. You'll get better at finding the centre. Steve
