7.5" Brake Disc Setup with 13" rims??
https://www.ausmini.com/forums/viewtopic.php?f=5&t=2351
Author:  Mini Cooper Mania [ Sat Oct 16, 2004 12:47 am ]
Post subject:  7.5" Brake Disc Setup with 13" rims??
Is it possible to run on a 13" rims with a set of 7.5" Brake Disc setup??
Cheers, :P
Mini Cooper Mania
Author:  drmini in aust [ Sat Oct 16, 2004 6:01 am ]
Sure it is. But if you are going to keep running wheels this big, why not fit something bigger in there, for better braking.
Or it'll look like this SSS Pulsar I saw yesterday, looked like had 18" wheels & 9" discs... :shock:
Author:  zippytheclown [ Sat Oct 16, 2004 6:44 pm ]
it's got something to do with rotating mass, a brake specialist could tell you. The discs have more work to do with bigger wheels because of the centrifugal force and inertia of the wider rims. you should think about bigger brakes, they're much cheaper than 's' stuff . You can use the 7.5's but they won't be as efficient as they are inside 10's
Author:  Mini Cooper Mania [ Sun Oct 17, 2004 1:31 am ]
Thanks guys much appreciated!!!!
Author:  Besser [ Tue Oct 26, 2004 7:16 am ]
Post subject:  Big Disks for drum hubs I could fit
The biggest combo I found to sit in 13"=
Volvo 4 pots (right angle brake line connectors)
Starrion rotors (massive thermal mass)
cooper studs
Fab caliper mounting plate
Fab disk mount to hub (disk screwed onto this)
Hyper Fang II 13x6 rims (needed for caliper clearance)
On drum hubs
These are massive (and heavy) considering the calipers are for a 1500kg car and the disks are for a 1200kg car it needed a rear adj bias and very large master cylinder
(volvo). The brake pedal has near no travel but very good feel.
**** I had reduced turn angle ****
